Latest post Thu, Apr 12 2018 5:22 PM by DonE. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Feb 26 2018 2:25 AM
    • ajrnz
    • Joined on Thu, Feb 9 2012
    • Posts 57
    • Points 730
    MC 2018.2 No Timecode with BWAV Audio AMA
    So on Media composer 2018.2 if you AMA to BWAV's it seems all time code starts at 00 hours.
    This was on a 25P project not sure about other framerates, If you use this wotk flow upgrading should be avoided
  • Fri, Mar 2 2018 4:13 PM In reply to
    • DonE
    • Joined on Tue, Aug 18 2009
    • California, USA
    • Posts 33
    • Points 400
    Re: MC 2018.2 No Timecode with BWAV Audio AMA
    I just confirmed this on Mac and PC. Project 1080i59. I exported a mono 24bit 48k wav from my timeline starting 00:58:59:28. I then linked it back to a bin (alt drop). The console shows the correct timecode start time but the master clip has a start time of 00;00;02;06. The export links fine in MC8.6.5.
    Don
    1x AMC/Sy 8.2.11-Win7 Pro 64-HP z800-dual 6core-24GB-Quadro FX 4800-Nitris DX QT775 NV340.84* 3x AMC/Sy 8.2.11-Win7 Pro 64-HP xw8600-8GB-Quadro FX 3700... [view my complete system specs]
  • Fri, Mar 2 2018 5:21 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,417
    • Points 15,395
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hi ajrnz, Don,
      Can you confirm if this is the same issue? This has been logged as bug MCCET-2332.
    http://community.avid.com/forums/t/183743.aspx
    RalphC
    This is a test. Media Composer 8.8 w/Symphony option, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Fri, Mar 2 2018 7:04 PM In reply to
    • ajrnz
    • Posts 57
    • Points 730
    Hi Ralph,
          Yep that's the issue, really screwed us up for a day or so! Glad I didn't upgrade earlyer!
  • Wed, Apr 11 2018 6:13 PM In reply to
    • DonE
    • California, USA
    • Posts 33
    • Points 400
    Now April 11 and MC 2018.4. Some of these problems go back to 2018.1 or before.
    Fixed in Media Composer v2018.4
    The following have been fixed:
    ➤ Bug Number: MCCET-2332. In some instances, audio files linked with the WaveAiff plug-in
    may have come in with the wrong duration.
    ➤ Bug Number: MCCET-2323. Audio files linked with the WaveAiff plug-in did not have the
    correct timecode.
    ➤ Bug Number: MCCET-2320. The Audio time-code rate in the Link Settings Link Options did
    not work when using BWAV Files (BWF).
    I retested linking a mono wav file I had exported from a Avid 1080i/59 project. On link in the Audio Start-Time Options I selected 29.97DF and the dialog correctly showed File TC: 00;58;59;28 (30). After clicking OK the Master Clip in the bin shows 00;58;59;27.
    I also tested relinking a wav export from a Avid 1080p/23 project. Selecting 23.98 on link it correctly shows 00:57:50:00 (24) and lands in the bin at 00:57:50:00.
    Looks like some timecode / rates work and some don't.
  • Thu, Apr 12 2018 11:27 AM In reply to
    • pierreh
    • Paris, London
    • Posts 1,195
    • Points 14,415
    Does TC work properly when you import instead of link to?
  • Thu, Apr 12 2018 5:22 PM In reply to
    • DonE
    • California, USA
    • Posts 33
    • Points 400
    pierreh:
    Pierreh,
    If I Import at 29.97DF with 2018.4 the In and Out Timecode are correct (00;58;59;28).
    Further Link testing shows that the Duration matches the Import Duration. The In and Out Timecode are both 1 frame ahead (00;58;59;27).
    This file Links correctly with MC8.2.11 and MC8.6.5.
    Don
