Latest post Wed, Feb 28 2018 7:40 PM by Marianna. 6 replies.
Page 1 of 1 (7 items)
  • Sat, Feb 24 2018 6:26 PM
    Production services UI changes.
    Dear Avid,
    While Mediacentral production services engine is one of the oldest products in the Avid product line, rock solid and the interplay user base is probably totally used to its functionality, I would like to ask if the Production services and transfer status user interface can be updated. Since its DMS broker times the individual engines have had new options added but the production services and transfer status UI was left untouched.
    My main reason for asking is the way error reporting is functioning within the UI.
    Example: I perform a restore action of media which is not present in the LTO archive library. The error message will say:
    third party software returns third party software returns DETPullv2 PerformAction RestoreAsset failed. Not all data requested are available. Please load <tape nr>
    Due to the UI layout the crucial information 'Please load <tape nr>' is often outside of the users view, even when the 'status text' column is dragged left to be the first column, as widening the columns to be able to read all text will, on a full hd monitor, still require the user not to be able to read the information in other columns.
    Now, apologies if I sound like Mr. wise guy, but has nobody ever considered to wrap the text in these columns?
    And even if this UI layout is 'good enough', can't the 'third party software returns third party software returns DETPullv2 PerformAction RestoreAsset failed' be truncated out and/or just be shown in the details?
    Seriously, when product managers and developers leave these 'third party software returns third party software returns DETPullv2' texts in for years and years it just shows nobody really cares about the end user experience.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Mon, Feb 26 2018 7:57 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 333
    • Points 3,875
    Re: Production services UI changes.
    +1 on this.
    Also - making the text available for the system clipboard instead of needed to go dig out a text file of the log from the server.
    Dave
    "A very big network"
  • Mon, Feb 26 2018 8:04 PM In reply to
    • Posts 10,079
    • Points 216,475
    Jereon and NYnutz
    Let me see what the interplay team has to say....
  • Wed, Feb 28 2018 3:05 PM In reply to
    • NYnutz
    • New York City
    • Posts 333
    • Points 3,875
    @Marianna, thanks!
    (can you also poke them about server 2016 failover cluster support?)
    Dave
  • Wed, Feb 28 2018 4:49 PM In reply to
    • Posts 10,079
    • Points 216,475
    Jeroen and NY
    They said it is doable.... but not until thr summer timeframe.
    At least we got that far!
  • Wed, Feb 28 2018 6:49 PM In reply to
    Hi Marianna,
    Thanks for the update. Great to hear Avid will look into it.
    I would just like to emphasize that the example I gave is just one of several messages that can be found inside the production services status and that a similar problem exists in the transfer manager status.
    The error reporting could be improved so (to use a Douglas drbgaijin term) mere mortals can understand them. Specifically when the issue is not a system failure but a workflow related problem.
    Jeroen van Eekeres
  • Wed, Feb 28 2018 7:40 PM In reply to
    • Posts 10,079
    • Points 216,475
    Jeroen
    I just sent the Interplay team that message ----  errors that mere mortal can understand = priceless.
    marianna
