Latest post Fri, Mar 16 2018 4:29 PM by Job ter Burg. 13 replies.
Page 1 of 1 (14 items)
  • Mon, Feb 19 2018 1:01 PM
    Motion effect -> wrong aspect ratio
    This is a thread with two mixed topics. They include wrong aspect ratio on files with a timewarp effect.
    So if I put a 23.97fps file into a 24fps project and set it to 100% in Motion Effect Editor, the aspect ratio gets warped. Or if I put a motion effect, say 200% on a clip, the same happens. In both Source/Record.
    Help?
    Thomas
    i7 3.4 GHz | Asus HERO Z170 | 32GB Ram | Quadro k620 | Intensity Pro 4K | WIN7 64bit Pro [view my complete system specs]
  • Mon, Feb 19 2018 1:12 PM In reply to
    Re: FrameFlex weirdness - FullHD MXF is cropped, wrong aspect ratio
    When I open the MXF with Telestream Switch, it looks ok btw
  • Mon, Feb 19 2018 4:12 PM In reply to
    Ok, I updated MC to 2018.2 and the issue is gone. Strange.
    Solved
  • Sun, Mar 11 2018 10:22 PM In reply to
    It´s back - when I put a motion effect on a clip. Anyone else has this? Any ideas?
  • Mon, Mar 12 2018 3:55 PM In reply to
    Is this in the source monitor or just in the timeline? Have you tried refreshing the aspect ratio/reformatting setting in the refresh sequence menu?
    Andi
    Macbook Pro (Retina, 15-inch, mid 2014) 2.5GHz Core i7 16GB 1600 MHz DDR3 NVIDIA GeForce GT 750M 2048MB MacOS Sierra 10.12.6 MC 2018.9.0 Symphony... [view my complete system specs]
  • Mon, Mar 12 2018 3:59 PM In reply to
    Hi Andi, it´s on both sides including HDMI output via decklink. Refreshing doesn´t change anything :(
  • Tue, Mar 13 2018 1:03 PM In reply to
    • Filetillo
    • Joined on Tue, Mar 13 2018
    • Posts 1
    • Points 5
    Hello! Same problem here. Any way to solve it?
  • Tue, Mar 13 2018 6:24 PM In reply to
    Re: Motion effect -> wrong aspect ratio
  • Wed, Mar 14 2018 8:44 AM In reply to
    I have an editor who is on version 8.9.3 and has the same issue.
    We are on version 8.8.3 and have no issue with the same material, same project, same settings etc.
    It would seem then that it is something to do with the version of the media composer.
    Can anyone confirm if they have or do not have thisw issue?  And what version they are on?
    Avid Media Composer 8.9.3 | Mac OS 10.13.2 | Editshare 7.2.1.2 [view my complete system specs]
  • Wed, Mar 14 2018 9:48 AM In reply to
    I’ve added this thread to the support case. Thanks for adding the version info, that is valuable intel.
  • Wed, Mar 14 2018 1:30 PM In reply to
    I´m on 2018.2 btw. I found something else: Clips in DNxHD 36 aren´t affected, only DNxHD 80. In the bin column Image Framing, the 80s are marked 'source cropped', the 36s lack an entry.
  • Wed, Mar 14 2018 4:18 PM In reply to
    So as a workaround transcode into DNxHD 120 for example, doesn´t seem to be affected as well as 36.
  • Fri, Mar 16 2018 8:44 AM In reply to
    Job ter Burg:
    This thread suggests that DNxHD 80/85 is full raster in 1080P 24/25 projects.  SO that cannot explain the issue here, correct?
  • Fri, Mar 16 2018 4:29 PM In reply to
    Well, it all seems to center around DNxHD80/85/100, which is why I've added this thread to that case.
