Latest post Thu, Feb 15 2018 11:43 PM by AndrewAction. 0 replies.
Page 1 of 1 (1 items)
  • Thu, Feb 15 2018 11:43 PM
    Media Composer v2018.2 -- NOW AVAILABLE
    Avid is pleased to announce the latest release of Media Composer v2018.2 on February 15th, 2018. The software is available through My AvidAvid Application Manager, or the Download Center (login and password required). You must have a current Support & Upgrade plan to run the latest software.
    This release is supported on
    Windows v7 64-bit SP1(Professional) and Windows v8.1 (Professional and Enterprise),
    Windows v10 64-bit (Professional, Creators, and Enterprise).
    macOS 10.10.5 (Yosemite), 10.11.6 (El Capitan), 10.12.6 (Sierra) and 10.13.2 (High Sierra).
    - Live Waveform Update in Color Correction tool
    - Avid Color Control Surface improvements
    - Quick Access to Grid Settings
    - AVX2 Plug-in Names on Splash Screen.
    - Setting Font and Font Size in the Find Window.
    This release addresses 30+ bugs since the last release, including:
    - You would lose full transparency when cropping an image with an alpha channel.
    - CTL + Z did not always work for undo within the Effect Editor with Boris Effects.
    - In some instances, making audio adjustments did not affect rendered audio effects in the timeline.
    See the ReadMe or What's New documents published on the Knowledge Base prior to upgrading if you have any questions.
    If you have general issues with installing or running the release, post them here. If you think you have found additional bugs, please start a new thread.
