Latest post Thu, Mar 15 2018 4:04 PM by Kevin Klimek. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Feb 15 2018 9:31 PM
    Media Composer v2018.2 -- AVAILABLE
    Avid is pleased to announce the latest release of Media Composer v2018.2 on February 15th, 2018. The software is available through My Avid, Avid Application Manager, or the Download Center (login and password required). You must have a current Support & Upgrade plan to run the latest software.
    + OS SUPPORT:
    This release is supported on macOS 10.10.5 (Yosemite), 10.11.6 (El Capitan), 10.12.6 (Sierra) and 10.13.3 (High Sierra).
    + NEW FEATURES:
    - Live Waveform Update in Color Correction tool
    - Avid Color Control Surface improvements
    - Quick Access to Grid Settings
    + BUG FIXES:
    This release addresses 30+ bugs since the last release, including:
    - You would lose full transparency when cropping an image with an alpha channel.
    - CTL + Z did not always work for undo within the Effect Editor with Boris Effects.
    - In some instances, making audio adjustments did not affect rendered audio effects in the timeline.
    + FOR MORE INFORMATION:
    See the ReadMe or What's New documents published on the Knowledge Base prior to upgrading if you have any questions.
    If you have general issues with installing or running the release, post them here. If you think you have found additional bugs, please start a new thread.
  • Thu, Feb 15 2018 10:45 PM In reply to
    • erik1185
    • USA
    • Posts 1,055
    • Points 12,995
    Re: Media Composer v2018.2 -- NOW AVAILABLE
    No macOS High Sierra 10.13.3 support?
    Late 2013 MacBook Pro, 2.4 GHz Intel Core i5, 8 GB RAM, Intel Iris 1536 MB Graphics [view my complete system specs]
  • Thu, Feb 15 2018 10:47 PM In reply to
    It's not listed in the Readme but I'll check...
  • Fri, Feb 16 2018 3:54 PM In reply to
    • Posts 9,714
    • Points 211,660
    Yes it is now approved...
    ReadMe updated
    http://resources.avid.com/SupportFiles/attach/README_Avid_Editor_v18.2.pdf
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Fri, Feb 16 2018 4:06 PM In reply to
    And the initial post in this thread has been corrected to include that.
  • Fri, Feb 16 2018 4:19 PM In reply to
    • erik1185
    • USA
    • Posts 1,055
    • Points 12,995
    Awesome, thanks!
  • Fri, Feb 16 2018 7:20 PM In reply to
    • Corkey
    • Joined on Mon, Sep 7 2015
    • Posts 18
    • Points 195
    In practical terms, the ability to upgrade the OS to 10.13.3 means we can also fix a known, nagging issue where copying/handling files over a local network would result in Finder crashes. I've just upgraded to 10.13.3 and 2018.2, have tested, and can confim this finder crash issue is now a thing of the past! Thanks Avid!
    Retina MacBookPro 15" 16GB (mid-2012); iMac 27" 4.0 quad-core Intel Core i7, Turbo to 4.2, 32GB, (late 2015). [view my complete system specs]
  • Wed, Mar 14 2018 12:27 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,207
    • Points 14,615
    There is a new version out, v2018.3. At least on the PC side of it.
    I'm still on 8.10, couple of bugs, I will only bother to update if a couple of really annoying bugs are gone.. They're more like interface details that were forgotten than bugs:
    - If I solo a sound track, or mute a sound track in the Timeline for a clip loaded in the left window of the Composer (rushes then, not my current sequence), when I hit play, it's the sequence which starts to play. Very annoying. It sort of makes sense from a programming point of view, as indeed the forefront window is the Timeline. But from an editing point of view, it's a waste of time. Previous versions of MC behaved the way the editor expected and at some stage it was broken and never fixed.
    - 8.10 (or was it 8.9?) brought back the possibility to navigate in the mixer using the Tab key. That had disappeared with the new narrow mixer - it just wasn't programmed at all. But the way it was brought back is half baked: if I click on the fader, I can change its level with the Up/Down arrow keys on the keyboard (or Shift arrow to move by a full dB per stroke), but I can't move to the next fader with Tab. I can only move to the next fader if I click on the dB display at the bottom of the mixer. Of course one can argue that I should retrain my muscle memory, but I disagree: if you give me a mixer that looks like a real mixer, then you have to expect me to put my finger (I mean mouse) on the fader. And afterall, the "old" wide mixer behaves more logically.
    Those two are very annoying bugs (again, as I wrote earlier, they're more missing features that used to exist than bugs) as those are tools which an editor uses hundreds of time per day, if not thousands.
  • Wed, Mar 14 2018 5:54 PM In reply to
    Have you checked out the bugs fixed by 2018.3 Pierre  Read Me here   (Not saying that yours are there)
  • Thu, Mar 15 2018 3:11 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,207
    • Points 14,615
    That one is a bit slim on the description side:
    Bug Number: MCCET-2300. Match Frame was not working properly for audio on a group clip.
    I guess I'll have to try the new version and see...
  • Thu, Mar 15 2018 3:46 PM In reply to
    • nigelad
    • London UK
    • Posts 492
    • Points 5,665
      Avid Certified User
    Re: Media Composer v2018.2 -- AVAILABLE
    Do I still need to un-install 18.1 before installing 18.2?
    Nigel
    ISIS 5500, with Interplay Production bundle, mainly MC 8.6.1 & PT 12.5.1 on Mac OS X.11.3 with BM Mini-Monitors and AJA T-taps. Running on 2013 Mac... [view my complete system specs]
    Less IS More!
  • Thu, Mar 15 2018 4:04 PM In reply to
    It is supposed to work, but honestly I have just always use the uninstall/install method to prevent any potential issues.
    And BTW, 2018.3 is out now as well.
