Latest post Mon, Feb 19 2018 1:39 AM by Martin Fox. 3 replies.
  • Wed, Feb 14 2018 7:18 AM
    • ADG
    • Joined on Wed, Feb 14 2018
    • Posts 2
    • Points 30
    Hard Drive setup/allocation + Workflow
    Hello,
    Sorry if this has been answered before but I have found lots of conflicting information and would greatly appreciate some help.
    I am getting a PC built for Media Composer editing from my home studio.
    I was wondering which type of Internal Hard drives I should get built into this PC and the best workflow for efficiency. Would it be more beneficial to run an external raid type setup and only have the internal ssd for the operating system etc? A good backup system is also required.
    I understand that having a ssd for the operating system and software makes sense. But I am confused which options to use for projects, media storage, rendering, consolodation, archiving etc etc.
    I have a budget of approximately 5k for the PC and storage.
    Thanks for your help.
    ADG
  • Wed, Feb 14 2018 10:44 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 99
    • Points 1,045
    Re: Hard Drive setup/allocation + Workflow
    Here is my hard drive set up (using external sata 4 bay x 3, all drives are removable )
    Drive ‘1’ is the project drive: graphics, photos music, camera originals, basically all the project assets, backed up everyday
    Drive 2  video meadia drive (Avidmediafiles folder)
    Drive 3 Audio meadia drive (Avidmediafiles folders
    Drive 4 render drive
    next 4 bay case has a fast raid for high Rez media when uprezing long form stories
    next 4 bay has consolidate and archive drives
    The basic idea here is to have the dives separated into those that are reading and those that are writing, for example ;
    camera originals are read from the project drive  (using the “link” command) and written (transcoded) to the media drives, another example, when rendering, the media is read from the media drives an written to the render drive, another example, when consolidating, the media is written to the consolidate drive.
    You don’t really need the raid drive, unless you are working on high Rez or long projects.
    Workflow
    link to the camera originals
    Transcode camera original to appropriate avid media
    import music graphics etc
    edit
    render out approvals ( I still use reference quick times and a external media encoder to make mpeg4 movs)
    Up Rez and export
    Consolidate and archive the ‘edit’ , and the original project assets
    Wish it was that simple
    iMac Retina27 late 2017 4.5Gz i7 40GB AMD 8GB with Sata Raid OS 10.13 MC 8.9.4 BMD mini monitor with Eizo monitor [view my complete system specs]
  • Fri, Feb 16 2018 11:40 AM In reply to
    • ADG
    • Posts 2
    • Points 30
    Thanks for the information.
    The setup I was planning was.
    Internal Hard Drive 1 - ssd 500g - Operating system and applications
    Internal Hard Drive 2 - 2tb - Projects
    Nas 4x 4tb = 16tb (for all my media, exports and archive).
    External 2tb drive - for renders/cache etc
    Does this look ok for a small/medium budget setup?
  • Mon, Feb 19 2018 1:39 AM In reply to
    • Martin Fox
    • Sydney Australia
    • Posts 99
    • Points 1,045
     Difficult to say if it’s okay for small set up depends on the size of the work you’re doing.
    Couple of points, have you tried the nas connection with the Rez you want to cut at?
    2tb seems a bit small to me, for a project drive, 3-4 tb seems like the sweet spot for price per gig in my country
    you can always expand! I find the write speed of the render and export drives to be important, to make that process efficient, as my cuts for approval are often over an hour, and to meet deadlines , Speed is essential.
    let us know how you go...
