Latest post Fri, Feb 9 2018 7:52 AM by Job ter Burg. 3 replies.
  • Tue, Feb 6 2018 9:12 PM
    Capture hdcam sr, progresiv or psf?
    I got at Hdcam sr tape 25psf.
    Witch format settings do I need to set in the project, 25p or 50i?
    Best
    David
  • Wed, Feb 7 2018 7:57 AM In reply to
    Re: Capture hdcam sr, progresiv or psf?
    Both will work (also depends on your deck’s output settings). Also depnds on yoir delivery requirements. I would stick to P, since you can always change that to i if needed.
  • Thu, Feb 8 2018 1:34 PM In reply to
    My Sony Hdcam SR only support 25psf or 50i.
    And I want to make a 25 progressiv frame file delvery.
    As I know 25psf can be captured in 50i, but not in a true 25P capture. If thats right ? Is 25p in the avid captured as psf?
    Best
    David
  • Fri, Feb 9 2018 7:52 AM In reply to
    David Nielsen:
    No, PsF is the common signal for HD-SDI capture into P projects.
    PsF is just a signal transfer format. So set the deck to PsF, capture over HDSDI into MC into a 25p project.
    If you happen to have already captured in 50i, just open the clips in a 25p project, and designate the clips as being Progressive in the Field Motion column in the bin.
