Latest post Thu, Feb 15 2018 12:56 AM by A. 11 replies.
Page 1 of 1 (12 items)
  • Sun, Feb 4 2018 4:31 PM
    • A
    • Toronto
    • Posts 56
    • Points 770
    Upgrading GPU
    Hey everyone,
    I'm looking to upgrade my graphics card from NVIDIA Quadro K2000 to a Quadro P2000 or a NVIDIA Quadro P4000.  I looked up the spec sheet on the Z420 and said it can handle the Quadro 4000 and the K4000, but nothing about the P4000.  My guess is because the card didn't exist when the spec sheet was created... so that's why it's not there.  I am concerned about the power supply and if the computer can fully handle it.
    Also, what are your throughts about the the P2000 vs K4000?  I take it there will be a noticible difference with Avid and the two cards; or will there be?  I generally want to upgrade the workflow working within Avid and BCC effects... don't like the waiting; just wondering if the K4000 is worth the extra money.
    -A
    __________
    HP Z420 Workstation  | Intel Xeon CPU E5-1620 @ 3.60 GHZ 3.60 GHz | 32 Gigs of RAM | NVIDIA® Quadro® K2000 | Windows 10 Pro 64 Bit | Blackmagic Design Intensity Pro 4K  | Samsung SSD 840 SCSI HDD | CalDigit VR2 6 TB Media Drive
    HP Z420 Workstation | Intel Xeon CPU E5-1620 @ 3.60 GHZ 3.60 GHz | 32 Gigs of RAM | NVIDIA® Quadro® K2000 | Windows 10 Pro 64 Bit | Blackmagic Design... [view my complete system specs]
  • Sun, Feb 4 2018 11:38 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 466
    • Points 5,480
    Re: Upgrading GPU
    i'd go for gtx 1070.
    find a model with only one fan, those blows heat out of the chassis.
    the world is out of gpus though, because cryptomining.
    check the wattage of your PSU, if it's over 550W you're good to go.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Tue, Feb 6 2018 12:28 AM In reply to
    • Mark
    • Joined on Sun, Dec 19 2010
    • Posts 431
    • Points 4,645
    Re: Upgrading GPU
    Z420 config guidline http://resources.avid.com/supportfiles/config_guides/AVIDHPZ420ConfigguideRevD.pdf last update Aug. '14. P series Quadro didn't exist at the time.
    Quadro 4000 is ~8 years old. They run really hot. Consequently, the fan runs really loud. Distractingly so. I still have one on the shelf. Replaced it with K4200. Not silent but adequately quiet.
    Quadro through k4200 are PCIe2 cards if you've an old mobo. K5000 & newer/more powerful cards are all PCIe3.
    GeForce cards are significicantly less expensive than comparable Quadro cards. One is presumably better served by GeForce unless some software used (e.g. Mistika) specifies it uses a Quadro only feature.
    Avid specified Quadro once upon a time but not for a while. MC does not rely heavily on GPU processing. Not sure about BCC. DaVinci Resolve yes.
    BitCoin bubble has driven up GPU prices. Suggest waiting for bubble burst unless you need new GPU today.
    Hope this helps,
  • Wed, Feb 7 2018 1:23 PM In reply to
    Re: Upgrading GPU
    P2000 works excellent with MC.
    Desktop PC
    3 Heads Digital Films
  • Thu, Feb 8 2018 2:00 AM In reply to
    • A
    • Toronto
    • Posts 56
    • Points 770
    Re: Upgrading GPU
    The GTX 1070 is not worth it based on the current z workstation I own.  Last year I tried with a 1080 and the power consumption became a serious issue.  Plus Avid and Adobe After effects had problems seeing the CUDA cores to take advantage of the rendering capabilities... It was so much of a nightmare I just returned it.  I just want to plug a new video card and go.
    You are a big fan of the P2000?  I'll jump from 2 to  5 GB of GDDR5 ram.  That should show a serious change.  I'm just still on the fence if it's worth jumping to the P4000.  At this point, I'm really not interested in spending more than the P4000.
    If the heat and sound is an issue on the P4000, maybe I'll consider the P2000.  It gets a great rating for it's price and speed compared the others out there.
  • Thu, Feb 8 2018 12:35 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,402
    • Points 15,445
    Re: Upgrading GPU
    George Angeludis:
    +1
    V.
    AVID MC2018.12 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Fri, Feb 9 2018 7:18 PM In reply to
    • Mark
    • Posts 431
    • Points 4,645
    Re: Upgrading GPU
    Heat and sound is an issue on the quadro 4000 (no letter) mentioned in the old z420 config KB article. P4000 is ~4 generations newer.
  • Mon, Feb 12 2018 5:37 PM In reply to
    • Gretski
    • Posts 173
    • Points 2,310
    Re: Upgrading GPU
    M2000 with 4GB ram working with no issues
    Asus X299, i7 7820, Nvidia 2000M 32GB ram, NVME SSD 8.9.1 ( yes its very fast!) [view my complete system specs]
  • Tue, Feb 13 2018 12:49 AM In reply to
    • Harry Invision
    • Joined on Wed, Feb 3 2010
    • Brisbane, Australia
    • Posts 93
    • Points 1,125
    Re: Upgrading GPU
    P4000 working fine on Z840
    Media Comoposer 2018.4 + Symphony DX Nitris HP Z840 E5-2659 Quadro P4000 32Gb of Ram Win 10 64bit 64TB Editshare 16TB Internal Raid [view my complete system specs]
  • Tue, Feb 13 2018 1:56 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 169
    • Points 2,025
    Re: Upgrading GPU
    Using the P2000 with MC - no problems.
    Symphony 2018.12 - Win 10 pro, Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,64gig memory, 500gig SSD system drive, WD 5TB,and 2TB media, BM Intensity... [view my complete system specs]
  • Wed, Feb 14 2018 8:29 PM In reply to
    • fdooman
    • LOS ANGELES
    • Posts 515
    • Points 6,275
    Re: Upgrading GPU
    M4000 with 8gb works great for me.
    Symphony 6.0 on PC MC 6 on MAC Pro 3.2 GHZ 2008 model, 8 Gig of ram, Nvidia 8800 GT video card. 500 Gig system drive, 320 gig extra drive, Cineraid 2TB... [view my complete system specs]
  • Thu, Feb 15 2018 12:56 AM In reply to
    • A
    • Toronto
    • Posts 56
    • Points 770
    Re: Upgrading GPU
    I've decided to go with the P2000.  It's designed for the workstation and it gives me the boost I need to speed up my editing process/rendering without dropping over the $1000 pricepoint.  Thanks for everyone's feedback and help.
