Latest post Tue, Jan 30 2018 8:47 AM by BenoitM. 4 replies.
  • Mon, Jan 29 2018 2:46 PM
    • BenoitM
    • Brussels, Belgium
    • Posts 1,135
    • Points 13,710
    how to optimize program track CC on Symphony timeline with filler
    Pretty urgent:
    I have a long track containing mixed PiP media, some being regular video clips, some being stills (using BCC Pan & Scan).
    When I apply a Prog Track CC, the segments containing still images (BCC P&S on filler) are NOT corrected (seems to be in line with the documentation).
    I there a simple workaround, a way to CC the whole track at once (or quickly) i.e. without adding a CC effect to every still segment on the track (there are many of those) ? Since this is a PiP track, the underlying track should not be affected.
    Suggestions ?
    MC 2018.5 (Symphony option)/BCC 10.0.5/RED 5.6; Matrox MXO2 Mini (8.0.0); DELL Precision M4700 - Intel Core i7-3740QM 2.7 GHz - 24 GB RAM; nVidia Quadro... [view my complete system specs]
  • Mon, Jan 29 2018 10:07 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,244
    • Points 39,370
    Re: how to optimize program track CC on Symphony timeline with filler
    Well, I would save the the color effect in a bin, then select all the clips on the track in question (select in to out / no filler button) and then double click the saved color effect.  This should apply that effect to all the selected clips.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." | OS 10.11.x - various MacPro Towers - home system MacPro Dual 2.8 8core GTX680 "Harpertown"... [view my complete system specs]
    Jef Huey
  • Mon, Jan 29 2018 10:32 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,135
    • Points 13,710
    Yep, but unfortunately this replaces any existing effect on the target clips; AFAIK it is not possible to ALT-double click to apply on top (nest) of mutiple clips at once ?
  • Mon, Jan 29 2018 10:44 PM In reply to
    • jef
    • Maryland
    • Posts 3,244
    • Points 39,370
    Yes.  You are correct.  No more than one effect with that trick.
    I got nothin else.
    Jef
    Jef Huey
  • Tue, Jan 30 2018 8:47 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,135
    • Points 13,710
    OK -- too bad Prog Track CC doesn't apply to filler...will roll up my sleeves now ;-)
