Latest post Tue, Feb 20 2018 11:58 AM by nigelad. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jan 16 2018 8:39 PM
    Media Composer v2018.1 -- AVAILABLE
    Avid is pleased to announce the latest release of Media Composer v2018.1 on January 16th, 2018. The software is available through My Avid, Avid Application Manager, or the Download Center (login and password required). You must have a current Support & Upgrade plan to run the latest software.
    + NOTE:
    With this release, Avid is changing the versioning numbering system going forward. All releases will be named by year and month, with patch releases included after that. As this release is from January 2018, the version number is 2018.1. Any patch released this month will be named 2018.1.1, and so on. Any release in Feburary will be 2018.2; in March 2018.3, and so on.
    + OS SUPPORT:
    This release is supported on macOS 10.10.5 (Yosemite), 10.11.6 (El Capitan), 10.12.6 (Sierra) and 10.13.2 (High Sierra).
    + NEW FEATURES:
    - Mappable QuickFind Button
    - Exporting Separate WAV Files per Track
    + BUG FIXES:
    This release addresses several bugs since the last release, including:
    - When in Bin text view, you might have seen a horizontal row of black artifacts when resizing the bin.
    - When in the Effect Editor, pressing the period key would re4set the slider value to zero.
    + FOR MORE INFORMATION:
    See the ReadMe or What's New documents published on the Knowledge Base prior to upgrading if you have any questions.
    If you have general issues with installing or running the release, post them here. If you think you have found additional bugs, please start a new thread.
  • Wed, Feb 14 2018 9:32 AM In reply to
    • nigelad
    • London UK
    • Posts 501
    • Points 5,770
      Avid Certified User
    Re: Media Composer v2018.1 -- NOW AVAILABLE
    Hi
    I'm trying to install MC18.1 and iMac hangs on the reboot. Won't boot at all.
    This is on a new iMac - 3.6Ghz i7 with 32GB RAM, Mac OS 10.13.3.
    I had previously installed  Nexis Client v7.10 and PT v18.1. Both apps functioned fine.
    Any advice appreciated
    Nigel
    ISIS 5500, MC 18.4 & PT 18.4 on Mac OS with BM Mini-Monitors and AJA T-taps. [view my complete system specs]
    Less IS More!
  • Wed, Feb 14 2018 3:28 PM In reply to
    Haven't heard of an issue with the full computer not rebooting.
    Have you tried safe mode or recovery mode?
  • Thu, Feb 15 2018 11:31 AM In reply to
    • nigelad
    • London UK
    • Posts 501
    • Points 5,770
      Avid Certified User
    Safe mode stalls at the same point - about 3/4 of the way along the progress bar.
    Tried resetting NVRAM and SMC - no difference.
    Tried booting in "verbose mode" - last line says "IOConsole users g!)ScreenLockState 3, hs 0, bs 0, now 0, sm 0x0"
    There appears to be no local recovery partition, and I can't boot system to enable Wifi or set ethernet connection :(
    Going to have to re-install from a bootable USB drive, and install all over again.....
    Less IS More!
  • Thu, Feb 15 2018 3:53 PM In reply to
    Yeah, I'm guessing your issue is larger than MC. Let us know how the reinstall works.
  • Tue, Feb 20 2018 11:58 AM In reply to
    • nigelad
    • London UK
    • Posts 501
    • Points 5,770
      Avid Certified User
    Thanks.
    So far, so good with clean install Big Smile
    Nigel
    Less IS More!
