Latest post Thu, Apr 12 2018 3:16 PM by JPBU. 20 replies.
Page 2 of 2 (21 items) < Previous 1 2
  • Wed, Jan 24 2018 4:58 PM In reply to
    • derDoyle
    • Joined on Tue, Aug 18 2015
    • Berlin, Germany
    • Posts 81
    • Points 935
    Re: iMac Pro
    Of course it depends on your H264-Settings. But I tested the same settings on AME and Compressor and Compressor was always faster.
    I just encoded a ProRes444 (~170GB, 95min) into my standard H264-Setting (720p, 5MBit/s, 1pass CBR) in 9 minutes.
    Same setting in AME needs 21 minutes.
    All files from and to the internal SSD.
    H264 doesn't split into segments. But the setting is activated. In compressor you can choose Instances, my setting is on 1 Instance. More is not better in this case.
    Clients: MacPro6.1 (2013 "Trashcan"), 3,5GHz 6-Core, 16GB (1866) RAM, AMD FirePro D500, 256GB SSD, macOS 10.12.2, Avid MediaComposer 8.7.2, NitrisDX... [view my complete system specs]
    Passionate In-House Avid Support
    Admin of the German Avid Community on Facebook
  • Tue, Mar 6 2018 3:56 AM In reply to
    • LJH
    • Joined on Tue, Mar 6 2018
    • Posts 1
    • Points 15
    Re: iMac Pro
    Hey there - I've got a project coming up in May and need to buy a second system. Obviously you can't promise anything but is there any chance that the iMac Pro will get certified before then? Or highly unlikely?
  • Tue, Mar 27 2018 8:46 AM In reply to
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 135
    • Points 1,830
    Re: iMac Pro
    I would also like an ETA on an official Avid certification for the (not so) new iMac Pro.
    Media Composer 2018.10 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
  • Tue, Mar 27 2018 11:51 PM In reply to
    • Posts 10,018
    • Points 215,685
    Re: iMac Pro
    Job asked that I chime in....   Thanks Job.
    There was a Nexis bug that was fixed and will be in the 2018.3 Nexis releasecomig shortly  No changes for MC were required.
    However, New iMac Pros have both thunderbolt and USB 3.0. Dongle works fine in USB connector.
    The MBP have 4 USB-C ports (with thunderbolt).  You would need an adapter or dock to plug in a USB 3.0 dongle.
    we have the Caldigit USB-C dock in house which works with the dongle.
    I expect approval imminently and will let the moderators like Job know so they can post when they are live.
    marianna
  • Thu, Mar 29 2018 7:36 PM In reply to
    • pianoman72
    • Joined on Thu, Feb 9 2006
    • Dallas, TX
    • Posts 515
    • Points 5,920
    Re: iMac Pro
    Would you all that use it for transcoding feel comfortable with it exporting videos for long periods of time?
    I've seen some rather amateur reviewers on YouTube ding it for insufficient cooling during gaming stress tests, for example.
    Media Composer 8.3.1, OSX 10.9.5 [view my complete system specs]
  • Thu, Apr 12 2018 3:16 PM In reply to
    • JPBU
    • Canada
    • Posts 135
    • Points 1,830
    Re: iMac Pro
    From the AVID Blog:
    iMac Pro Support
    Avid Media Composer 2018.4 is now supported on Apple’s iMac Pro. Note that the iMac Pro will require the NEXIS 18.3 client.
    You can find a complete list of qualified Mac and Windows workstations, laptops, and Operating Systems in the ReadMe document.
    http://www.avidblogs.com/media-composer-2018-4/
