Latest post Tue, Jan 2 2018 1:19 AM by AsafBlasberg. 0 replies.
Page 1 of 1 (1 items)
  • Tue, Jan 2 2018 1:19 AM
    Question about Timecode
    Hello,
    I have a question about timecode.  What is the difference between using RP188 timecode and timecode using RS422 serial deck control to an HDCAM tape deck? I have a HDCAM deck which apparently supports RP188 timecode when you go out the SD-SDI output (standard definition). That output goes into a Blackmagic Shuttle to generate a uncompressed SD file, which is then used a source to encode to MPEG-2 for DVD authoring.
    When you use RS422 deck control, i wonder if the timecode that's displayed on the deck gets then transferred out the SD-SDI output.
    Any thoughts?
    Thank you.
