Latest post Sat, Dec 23 2017 5:33 AM by luca.mg. 4 replies.
  • Fri, Dec 22 2017 8:32 PM
    • Scott
    • Joined on Wed, Nov 30 2011
    • Utah
    • Posts 21
    • Points 275
    A way to quickly re-import files that were imported before power loss?
    Here's the set-up:  I was importing a bunch of files overnight into my Avid system (Composer 7.0, PC), and was near the end of the import process when I lost power.  As expected, when I restarted the computer later, and opened the program and the bin I was importing the files into, there was nothing there, because my system doesn't do any auto-saves while batch importing (is there a way to change that, by the way?).  So while most of the files DID get copied onto the hard drive, because I can see them in my ../AvidMediaFiles/MXF/1 folder, they don't show up as media files in my project.  I know I can just re-import them, but thought I might save myself a 12-hour import session if there is some way to quickly "relink" existing .mxf files that were imported already but not saved in the project bin.  Any suggestions or thoughts? TIA.
    Windows 7, 64-bit Intel Core i7 CPU @2.93 GHz 16 GB RAM NVIDIA Quadro FX 570 Graphics [view my complete system specs]
  • Fri, Dec 22 2017 8:54 PM In reply to
    Re: A way to quickly re-import files that were imported before power loss?
    Use the old trick.
    Trash the media databases in that MXF/1 folder. Let MC rebuild them. Then drag msmMMOB.mdb to an empty bin.
    All the valid clips in that 1 folder will be listed.
  • Fri, Dec 22 2017 9:18 PM In reply to
    Try opening a new bin and add the Creation Date column to your bin view.  Then drag the msmMMOB.mdb file from your Avid MediaFiles\MXF\1 folder into this bin.
    The bin will populate with ALL the MEDIA CLIPS in the 1 folder.
    Go to the Creation Date column and Sort  (Ctrl E) to get the bin started with the newest imported clips at the top.
    Select from the top clip to the first clip of your import.
    Create another new bin and move the selected clips into this Bin.  These should be all of the imports that were successful before the power cut.
    Rename the original bin created in this process to Duplicate clips. FWIW I prefer to make a Duplicate Clips folder and move the bin into that.
    Alternately if you know what you are doing and take great care you can select all the clips left in the first bin and hit Delete.  MAKE SURE you ONLY have "Delete Master Clips" selected in the pop up dialog box.
    (IT will be a complete disaster loosing you all of your previous media in the 1 folder if you mistakenly checked the Associated Media Files option in the delete dialog box.)
  • Fri, Dec 22 2017 9:26 PM In reply to
    • Scott
    • Utah
    • Posts 21
    • Points 275
    THANKS!  IT WORKED!  I could hug you.  I just created a new bin, dragged the .mdb file in (didn't know you could even do that!), and just selected the files I needed and dragged them back into the original folder.  I will definitely be keeping this trick in mind for future reference, as this isn't the first time this sort of thing has happened.  I'll still have to re-import the file that was being processed when I lost power, but this saves me a ton of time.  Thanks again!
  • Sat, Dec 23 2017 5:33 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,500
    • Points 64,515
    To be precise: there's no need to import the mdb file from the media folder, opening the media tool will suffice, You can  easily retrive Your clips digging among those belonging to the current project only, while drag and dropping the mdb file will populate the target bin with all the online clips in Your system, belonging to whichever project.
    Symphony 2018.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
