Latest post Tue, Jul 3 2018 5:36 PM by luca.mg. 14 replies.
Page 1 of 1 (15 items)
  • Mon, Dec 11 2017 12:28 PM
    MC 8.9.3 duplicates sequence into thin air - lost an hour of work
    Editing a sequence, I made a duplicate. Worked on it. Saved. Closed MC. Reopened after working a different project. Opened bin. Sequence gone. WTF?
    So, duplicated the old sequence. THE NEW SEQUENCE DOES NOT SHOW UP IN THE BIN. Using Find Bin MC tells me that it would be located in a bin named 'Color Correction Presets'.
    I had a lot of crashes with Avid in my life, but never lost more that 5 minutes of work. Thats a new one. Really angry right now.
    Super Angry
    i7 3.4 GHz | Asus HERO Z170 | 32GB Ram | Quadro k620 | Intensity Pro 4K | WIN7 64bit Pro [view my complete system specs]
  • Mon, Dec 11 2017 12:55 PM In reply to
    Re: MC 8.9.3 duplicates sequence into thin air - lost an hour of work
    By now I found that it´s already reported as bug
    Super Angry
  • Mon, Dec 11 2017 2:18 PM In reply to
    • Mat Linnett
    • root6 - A Jigsaw24 Company
    • Posts 5
    • Points 85
    Hi Thomas;
    Sorry to hear of your trouble!
    Have you checked your attic to see if there's a recent copy of the bin saved there?
    To find your attic, please refer to this KB article:
    http://avid.force.com/pkb/articles/en_US/FAQ/Avid-Attic-Locations-for-local-shared-and-synced-projects
    Once you have found the attic, you will see it contains folders named after your projects. Each of these contains a folder called "Bins", which in turn holds copies of bins associated with your project that are saved off at regular intervals. The default autosave interval is 15 minutes (found in "Bin" settings).
    Once you've identified the file you want, copy it, paste it to your desktop and remove the numeral suffix (ie: .1), then make sure the file has the correct bin suffix (.avb).
    You can then open this copy of your bin in Media Composer.
    Apologies if you have already tried this, but if not, I hope you are able to find your sequence!
  • Mon, Dec 11 2017 8:02 PM In reply to
    Hi Mat,
    yes I went to the attic, but as the bin in question does not really exist, there is no attic copy of it. At least I didn´t see any named 'Color Correction Presets'.
    That´s what makes this so mean, attic is usually a lifesaver...
    I will look out for this behaviour, maybe it´s already fixed in 8.9.4, which I installed immediately after...
    Cheers Thomas
  • Mon, Dec 11 2017 8:05 PM In reply to
    Forum´s kinda lagging as well, oh my...
  • Mon, Dec 11 2017 8:33 PM In reply to
    • Posts 10,227
    • Points 218,320
    Thomas
    Not sure what you mean by this " Forum´s kinda lagging as well, oh my...".....
    Explain
    marianna
  • Mon, Dec 11 2017 8:47 PM In reply to
    Hi Marianna,
    I double posted because my answer post just wasn´t there after sending it, so I wrote it again, and after I posted the second one, my first post showed. Guess the server is busy... Not my day today with computers Wink
    Cheers Thomas
  • Mon, Dec 11 2017 8:53 PM In reply to
    • Posts 10,227
    • Points 218,320
    Thomas - you still stuck?
    email me if you are... address below
  • Tue, Dec 12 2017 1:13 PM In reply to
    I have had several cases of bins vanishing lately.  Lots of work lost.  Nothing in the attic, nothing in the project.  Very odd.
    MC/SN 2018.6+7+8+9+12 x 16 Z400/420/440 PC's on W7 x64. 2 x Mac, 4 x PT 12.8.1 HDX, S6 all on PCs. ISIS 5000 X 2. [view my complete system specs]
  • Tue, Dec 12 2017 3:20 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 169
    • Points 2,025
    I usally back up my project/sequences frequently on an external hard drive - just in case a sequence gets lost.  I realize it is  time consuming  and a pain -  however when working on a edit sometimes I do not alwys use this method.  So I sure hope avid addresses this issue-  Not sure if I will upgrade until I know for sure this problem is resolved.
    thank you
    Symphony 2018.12 - Win 10 pro, Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,64gig memory, 500gig SSD system drive, WD 5TB,and 2TB media, BM Intensity... [view my complete system specs]
  • Tue, Dec 12 2017 6:39 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,557
    • Points 65,175
    Do not know if this applies to the OP, but I've seen this happening only once in over 25 years of Avid editing, and it was probably due to operator error: after one of those error messages that pop up following a software error I was given the option to exit or continue, I continued, just to find out on the following day that the changes were not saved, even if MC appeared to be saving while I kept working. Four hours of work vanished. Ever since then I exit and restart the all computer when I am given the option to either continue or quit following an error/crash/whatever. The attic did not save me, since all of the safety bin copies were the same, not updated after the malfunction, and a backup would have been useless, since the Avid was appearing to save, while in fact saved the bin without writing the changes to the sequence. Never understood the reason behind this, but lesson learned: quit MC after an error message, and to make sure no faulty code is preserved in RAM restart the computer too.
    peace luca
  • Tue, Jul 3 2018 11:34 AM In reply to
    • Roger Owen
    • Joined on Wed, Jun 21 2006
    • The New Forest, South Coast, UK
    • Posts 101
    • Points 1,255
    If this is a bug - it's still there in 8.9.3 purchased last month (June 2018)
    Right click in record monitor, select duplicate, appears in timeline but not in bin selected (or any other bin as far as I can see). Even saving the project does not save the duplicated file - which can lead to big problem.
    Safest work around that I found today was:
     Select sequence that you want to duplicate in bin,
    Go to Edit tab, left click and select duplicate.
    Duplicated file will now appear in the bin.
    Hope this helps.
    Hopefully it's something Avid are working on?
    Avid Media Composer 2018.11, Kona 3, HP XW8600 2x3.16 Ghz Quad Zeon (X5460), 8 Gb RAM, Windows 7 Pro 64 bit. Nvidia GeForce GTX 560 Ti. [view my complete system specs]
    Lots of kit... only one pair of hands!
  • Tue, Jul 3 2018 1:45 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,557
    • Points 65,175
    You can also select the sequence in the bin and hit CTRL-d. Not seeing this supposed bug in MC 2018.x. Is leaving 8.9 and jumping to 2018.5 an option?
    peace luca
  • Tue, Jul 3 2018 1:53 PM In reply to
    • Roger Owen
    • Posts 101
    • Points 1,255
    Yes, control D should work too - just a shame to loose right click rec monotor.
  • Tue, Jul 3 2018 5:36 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,557
    • Points 65,175
    Right click on rec monitor works as it always did here with MC 2018.5, as it did with previous 2018.x releases.
    peace luca
