Latest post Thu, Dec 7 2017 5:58 PM by DStone. 1 replies.
Page 1 of 1 (2 items)
  • Wed, Dec 6 2017 10:13 AM
    5K FF pixel aspect ratio bizarreness
    Hi everyone,
    I have few questions :
    1) A 5120 x 2694 pixels image (5K FF) is 1:90 right? But as the pixel ratio is 1.069, it should look like 16:9, no?
    2) In a 1920 x 1080 Avid project, FrameFlex is set to Pillarbox. Lines are missing at the top and bottom of the screen, why? (considering my way of thinking in my first question)
    3) I'm asked to put a 1:85 filler because the operator framed the shots with it, but as I already have lines missing, the mask isn't visible. Do you think the image he put the mask on was cropped? What is the right way to go?
    I'm completely disoriented right now.
  • Thu, Dec 7 2017 5:58 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,309
    • Points 42,865
    Re: 5K FF pixel aspect ratio bizarreness
    You should probably edit this as a 2K DCI Full (2048x1080). That maintains the aspect ratio. If your final output is HD then you are probably better off cropping to size. Otherwise, change the import settings (settings->import) to resize image to fit raster format and then re-import your clips. This will get all of the image, but you'll have to manually resize them to recover the proper aspect ratio.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC 8.x (generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
