Latest post Thu, Dec 7 2017 5:40 PM by Monter. 12 replies.
Page 1 of 1 (13 items)
  • Sat, Dec 2 2017 8:13 PM
    • Monter
    • Joined on Sat, Dec 2 2017
    • Posts 14
    • Points 160
    No linking, only import
    I can't use linking, MCF wants to import video and audio (any) files. Doesn't metter the format of files. Project format is locked to 720x486@29,97 (NTSC) but I use 25fps. How to change the project format and enable linking?
    MBP 6,1 i7 2,8Ghz, 8GB, Maverics 10.9.5 [view my complete system specs]
  • Sat, Dec 2 2017 8:20 PM In reply to
    Re: No linking, only import
    Monter:
    I can't use linking
    Can't use linking why? What happens when you try that's keeping linking from working?
    Monter:
    If First works like the full version, you can't switch a project from 29.97 to 25. If you work in 25, you need to create a 25 project.
    Media Composer 2018.7 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT... [view my complete system specs]
  • Sat, Dec 2 2017 9:44 PM In reply to
    • Monter
    • Posts 14
    • Points 160
    camoscato:
    MCF wants to import files.
    camoscato:
    How to create a project other then NTSC? Every projects I try to create are NTSC by default and no options to change the format. Every clip i try to load must be imported not linked, so no prompt to change format if place in sequence (as in videos Get Started Fast) because they're NTSC already (after import).
    I'm confused.
  • Sun, Dec 3 2017 7:21 AM In reply to
    Monter:
    According to this link, you should be able to create PAL SD, 720, or 1080 projects. Can you post a screen shot of your select project window?
  • Sun, Dec 3 2017 9:41 AM In reply to
    Looks like an invalid character in the file path as listed
    /media Composer | First/
    Try removing the |
  • Sun, Dec 3 2017 10:17 AM In reply to
    • Monter
    • Posts 14
    • Points 160
    Tried different clips, different paths, MCF always wants to import.
  • Sun, Dec 3 2017 3:20 PM In reply to
    • Monter
    • Posts 14
    • Points 160
    Here you are.
  • Sun, Dec 3 2017 6:48 PM In reply to
    Hmmmm. The only other thing I can think of is to look at the Format tab of the Project window to see what's available. I'm sorry, but hopefully another MC-First user will come along with more information about how to create a 25 fps project.
  • Mon, Dec 4 2017 5:00 PM In reply to
    • Monter
    • Posts 14
    • Points 160
    I watched Tutorials from Avid site. I think if linking works I could change format and rate. Format tab:
  • Wed, Dec 6 2017 4:03 AM In reply to
    • tommix
    • Joined on Tue, Oct 14 2008
    • Posts 182
    • Points 2,290
    by chance is it iphone foottage?
    what happen if you let it import?
  • Wed, Dec 6 2017 6:45 PM In reply to
    • Monter
    • Posts 14
    • Points 160
    tommix:
    No, I try footage downloaded from link in my avid account, same as used in video tutorials (Inside The Edit).
    tommix:
    Footage importing to disk normaly but as NTSC. I can't change format and rate. Project format is NTSC by default and is locked but i need PAL or HD 25fps. Look at my screens posted above.
  • Wed, Dec 6 2017 9:01 PM In reply to
    • Posts 9,323
    • Points 206,845
    Monter....
    Have you read the user guide....  page 23 is where you want to start. The format tab is important here....
    http://resources.avid.com/SupportFiles/attach/MC_FirstUserGuide.pdf
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Dec 7 2017 5:40 PM In reply to
    • Monter
    • Posts 14
    • Points 160
    Marianna:
    Monter....
    Followed the guide, and: no preview in Source Browser works, can't drag any clip into source monitor, linking doesn't work, only import. Discovered if I click Import in lower left corner of Source Browser dialog box opens and I can choose default project raster and rate, can't change it in the future, only once for ever. I need to do it just after first open a Source Browser.
