Latest post Mon, Dec 4 2017 10:48 PM by Guywithcat. 14 replies.
Page 1 of 1 (15 items)
  • Fri, Dec 1 2017 4:48 PM
    stuttering in 4k ugh
    Hi
    We have a brand new HP z840, with dual E5-2634 v4 Xeon processors at 2.2ghz (10 cores each) and 32gb of ram. Video card is m4000 with drivers avid recommended. It is connected over cat-6 gigabit to an EVO SAN with 96tb and raid 5. We have a single 17 minute clip shot in AVC Intra 4k 422 on the Panasonic Varicam that is shot VLOG in an MXF wrapper -- and that plays fine. But as soon as we put like 1 or 2 color changes to it to make it brighter or darker, it starts to stutter. Am I missing something here? We also have the very very latest version of MC (I forgot the number but it was upgraded like a couple days ago to the newest) and an ARTIST I/O. Is it that my system is not strong enough? Seems like a crazy idea considering my friend edits this same stuff on his high end macbook, i think. What can we do?
    Help!?
    HP z840, with dual E5-2634 v4 Xeon processors at 2.2ghz (10 cores each). 32GB ram. NVIDIA m4000 video card. EVO SAN with 96tb and raid 5 over Cat6. Artist... [view my complete system specs]
    I think we need a few more digital HD formats
  • Fri, Dec 1 2017 5:01 PM In reply to
    Re: stuttering in 4k ugh
    Its likley to be pure CPU grunt as the bottleneck.
    The playback off the server is the same. The LUT is a realtime effect. The AVC Intra is very CPU inmtensive to decode.
    Then add on more colour corrections and you'll see it struggle.
    Transcode to DNxHR and see how that compares. My monies on it playing much better.
    also 2.2GHz CPU speeds aren't the fastest. Lots of cores is great but after a point they can't really help you.
    I prefer faster CPUs 3GHz or more. Those E5-2634 can go up to 3.3GHz thats 50% more CPU power.
    As for the mac book I think the fastest ones will run at 3.6GHz
  • Sat, Dec 2 2017 10:44 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 532
    • Points 6,770
    I'm afraid Pat's right. The demands that today's camera formats make on our systems mean that you really need both high core counts and high CPU speeds. Even this may not be enough when you start adding in noise reduction/de-bayering etc, which is why grading workstations often add two or more high-end GPUs or even additional specialist cards (eg. Rocket-X).
    You might be interested in this article by Puget systems about a single core i7 verses two Xeons.
    https://www.pugetsystems.com/labs/articles/Should-you-use-a-Dual-Xeon-for-Premiere-Pro-CC-2017-932/
    To be honest, 2.2Ghz CPUs are just not going to be able to perform as well as the latest Core i9 processors, which are turbo boosting to around 4.4Ghz.
    As Pat says, transcode your footage to Avid-friendly media and things will run a lot smoother.
    HP Z800, HP8760, SonnetFusion RAID, Mojo DX, Symphony 8.10, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Sat, Dec 2 2017 7:44 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Minneapolis MN
    • Posts 2,135
    • Points 22,905
    I agree I tranccode everything I injest and I have no issues using a mbp i 7
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Sat, Dec 2 2017 11:33 PM In reply to
    Thanks everyone. I really do not have the bandwidth to transcode what will be 200 hours of footage. This means I need to get new machines. Avid insists that this strenght CPU (Note - the compute has two of them) can handle 3-6 streams of 4k. That said, the idea it cannot handle a single stream of AMA linked footage seems hard to swallow. There is no bigger project here. We just did a simple test with one clip and a couple color effects. Is it possible there is more to this or is it almost definitely still the CPU? And if it is the CPU, why is avid saying 3-6 streams of 4k? I understand Avid likely means 3-6 streams of DNxHR but again, this is one stream in an MXF wrapper with no lut -- just a couple color effects and nothing else.
  • Sun, Dec 3 2017 2:01 PM In reply to
    Its all about the codec codec codec codec.
    MXF wrapped or not this is the difference between LongGOP media and frame based media. So yes DNxHR will outperform LongGOP source media by a mile.
    It isn't that its AMA linked (you can AMA linke DNxHR content and it will play fine) its the source codec. Great for aquision hopeless for editing.
  • Sun, Dec 3 2017 3:13 PM In reply to
    What is the pagefile of yours and are you on W10?
    Desktop
    Corsair RM750X/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.4/Corsair 32G DDR3/PNY Quadro P2000D(390.77)/Samsung 850 Pro SSD(OS) 256 GB/ 2x2TB WD RE4@RAID 0/LG BH16NS40/W10 Pro 64bit/Media Composer Software 2018.11 with Symphony Option on Dongle/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Sun, Dec 3 2017 5:43 PM In reply to
    You really need a lot of RAM for MC work. 16GB min I'd say 32GB better 64GB great.
    An SSD boot drive and fast media drives.
    Then pagefile isn't that significant. Normally it should be 1.5X the RAM amount.
  • Sun, Dec 3 2017 9:09 PM In reply to
    • AntCaladine
    • Joined on Tue, Sep 11 2007
    • Stourbridge, UK
    • Posts 330
    • Points 4,140
    A couple of questions for you.
    are you monitoring 10bit or 8bit. 10bit is more system intensive, so drop down to 8 until you’ve rendered or really need to see in 10.
    you say your footage is coming over cat6 network. How many other machines are accessing that san at the same time. Network isn’t that quick. Even worse if more accessing at same time.
    to test copy a file locally to your system drive. Hopefully ssd and try from there. It’ll prob perform better.
    as others have said. Transcode. I appreciate you’ve a lot of footage, but AMA isn’t for editing directly from. It’s for quick ingest.
    2x HP Z8 G4, 96GB ram, Win10 Pro 64bit, Nvidia Quadro P4000 8GB AMC 2018.4 1x HP Z820 16GB ram, Win10 Pro 64bit, Nvidia Quadro 4000 AMC 2018.4 2x Aja... [view my complete system specs]
  • Sun, Dec 3 2017 10:47 PM In reply to
    Hi all
    OK a few things. 1) Windows 10  2) 10 bit  3) No other machines are on the SAN. Not even mounted -- Zero. 4) We have 32gb of ram. but get this -- the moment we pen AVID it spikes to say we are using 95% of our ram. This is before we even open a project. When we open and HD or a 4k project it makes no difference. Ram use goes up to as much as 96% and never below high 80s. CPU usage never goes about 52% even when we play back the (Non-transcoded) footage with a bunch of effects on it. CPU use tends to hover around 40% with lows in mid 30s (soundsl ike the weather). Any reason the mere opening of Avid would use up all that memory?
    And if we need to transcode then we will. But right now, I am wondering why we are using so much memory???? Could this be the culprit to the stuttering as well?
    And an update -- we just  tried in Safe Mode and the same things happened.
    Oh we also have SSD boot drive.
  • Sun, Dec 3 2017 11:08 PM In reply to
    • Bruno M
    • London, UK
    • Posts 532
    • Points 6,770
    Guywithcat:
    When you say 'bandwidth', do you mean the space on on your media drives or the amount of time it will take?
    If it's the former, you could always transcode to a proxy format for the edit, link back to camera originals once you have picture lock and then transcode the required material to a final, high quality Avid MXF format.
  • Sun, Dec 3 2017 11:13 PM In reply to
    i mean time -- sorry about that!
  • Mon, Dec 4 2017 11:16 AM In reply to
    Make sure that the pagefile is handled by Windows 10.
    If you are on a version that supports cache settings, lower those to around 15-16g inside MC settings.
    Also use the yellow/green timeline output setting as at 4K you really dont need it that much.
    Desktop
  • Mon, Dec 4 2017 8:41 PM In reply to
    I will do all that but i just checked all the same specs on another machine that is an exact clone of this one here and it runs without stuttering, CPU is the same but memory is never over 40% so somerhing is happening on this machine. Help!?
  • Mon, Dec 4 2017 10:48 PM In reply to
    bbbuuummmppp
