Latest post Wed, Dec 20 2017 12:41 PM by Patrick. 22 replies.
Page 2 of 2 (23 items) < Previous 1 2
  • Mon, Nov 20 2017 11:35 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,281
    • Points 39,785
    Re: XDCam import. How do you do it?
    No, my tests were with XDCam 50, not EX. Glad I stumbled onto this thread and checked.  I have a big XDCam50 job coming and was getting ready to switch several machines to 8.9.3.
    Oh well.  This is why we test.
    Jef
    Jef Huey
  • Tue, Nov 21 2017 1:22 AM In reply to
    Have you got the latest Sony XDCAM disk software?  I seem to remember one of the early 8.9.x versions required that.
    FWIW with the PC's here I am using nablet_XAVC_XDCAM_AMA_Plugin_Setup_Win_4.5.0.1252.
  • Tue, Nov 21 2017 7:07 PM In reply to
    • jef
    • Maryland
    • Posts 3,281
    • Points 39,785
    AndrewAction:
    I downloaded and installed right before my test.  It was ver 4.5.2 I believe.
    Jef
    Jef Huey
  • Wed, Dec 6 2017 5:59 PM In reply to
    • jef
    • Maryland
    • Posts 3,281
    • Points 39,785
    Has anybody tried with 8.9.4?
    Jef
    Jef Huey
  • Wed, Dec 6 2017 11:21 PM In reply to
    jef:
    tried with 8.9.4?
    If "it" is refering to XDCAM HD at 50mbs then here are the results of a test just now. Using as a source an XDCAM HD Disk and an ancient PDW-U1.    MC 8.9.4.  tested installed on W7 SP1 then repeated with 8.9.4 on W10
    I had Enable legacy Import which in theory should stop Linking.  All the clips on the disk (selecting H:\clips) imported as both Proxy and 50MB. (A setting checked to force Prox and Full Res enabled.)It was fairly slow to link and each linked clip took about 5 seconds to load from bin to Source monitor.  (The U1 is USB 2 only)
    For "Legacy importing. Proxies came in quicker than the Linking above!!
    Then Batch Re-import selected clips worked
    Batch Re-Import from Timeline works.
    For EX I only have 35MB media on backup drives and not able to test this at this time.
  • Thu, Dec 7 2017 2:26 AM In reply to
    • jef
    • Maryland
    • Posts 3,281
    • Points 39,785
    Hmmm.  More to test tomorrow.
    Thanks.
    Jef
    Jef Huey
  • Fri, Dec 8 2017 9:03 AM In reply to
    I second Andrew's findings. Also no EX to test here.
    Avid reseller ACSR at Telmaco
    http://www.telmaco.gr/en/
  • Wed, Dec 20 2017 12:41 PM In reply to
    • Patrick
    • Joined on Wed, Feb 20 2008
    • Almere
    • Posts 6
    • Points 90
    Hi Jef,
    We are running against the same problem using a Sony U2 device. Newest AVID version and Nablet drivers.
    Same exception. And files won't AMA link. Did you find a solution instead of downgrading to an older version?
