Latest post Sun, Nov 19 2017 4:55 AM by AndrewAction. 7 replies.
  • Tue, Nov 14 2017 10:30 PM
    • David L
    • Joined on Tue, Oct 18 2011
    • Nashua, NH
    • Posts 6
    • Points 80
    NewBlue for AVID
    Evening,
    I know this has been asked on the Mac side, however I have NewBlue 5.0.170821 installed on my application manager and when I try to open it via MC I get a message to install NewBlue Titler Pro.  How do I get Avid MC to recognize that NewBlue is installed?
  • Tue, Nov 14 2017 11:04 PM In reply to
    Re: NewBlue for AVID
    With a W10 install I had luck with uninstalling NewBlue first.  Then using my Avid Application manager to download and install NewBlue.
  • Thu, Nov 16 2017 6:58 PM In reply to
    • David L
    • Nashua, NH
    • Posts 6
    • Points 80
    I installed via App manager, still not linking.
  • Fri, Nov 17 2017 1:39 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,368
    • Points 43,485
    You don't open the NB titler like the original titler or Marquee. You add it as a filter onto a clip in the timeline.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
  • Fri, Nov 17 2017 6:55 PM In reply to
    • David L
    • Nashua, NH
    • Posts 6
    • Points 80
    Alright I got it working however following the tutorial video it crashes then when I try to reopen it refuses to open.
  • Fri, Nov 17 2017 8:21 PM In reply to
    Which OS and what version of it are you using?   What version of MC?
  • Sun, Nov 19 2017 3:54 AM In reply to
    • David L
    • Nashua, NH
    • Posts 6
    • Points 80
    Windows 10
    MC 8.9.3
    NB 5.0.170821
    I can use it for a while then it stops working without warning or noticeable reason.  Only fix seems to be reinstall, reboot does not solve this bug.
    Error Message reads TitlerStandalone.exe has stopped working
    A problem caused the program to stop working correctly.  Windows will close the program and notify you if a solution is avaialble.
  • Sun, Nov 19 2017 4:55 AM In reply to
    My suggestion would be to contact NewBlue Support with the info from your most recent post here. Also include the URL for this thread ( http://community.avid.com/forums/t/182901.aspx ) so they have more background information.
    Good luck and please post the solution here when it is found. Thanks.
