Latest post Fri, Nov 17 2017 3:41 AM by alexfx. 2 replies.
  • Fri, Nov 10 2017 2:12 AM
    • alexfx
    • Joined on Fri, Oct 27 2017
    • Posts 12
    • Points 110
    WalkComposition Error
    Hello,
    I've checked in an AAF and now attempting to GetSegmentsFromComposition but the server returns a soap:Server fault code with a WalkComposition faultstring. However the sequence does show up in Interplay Access and can be loaded into Avid. What is the cause of this error?
    Cheers,
    Alex
  • Fri, Nov 10 2017 4:25 PM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 211
    • Points 2,600
    • Avid Developer Moderator
      Avid Employee
    Re: WalkComposition Error
    GetSegments contains simplified version of sequence parser compared to full feature Avid editors.
    If you can provide copy of the AAF in question I can submit it for review. Please be aware that sequence should be generated by Avid tools. Otherwise you need to use Avid editor to import it instead of direct check-in via WebSerivces.
  • Fri, Nov 17 2017 3:41 AM In reply to
    • alexfx
    • Posts 12
    • Points 110
    Turns out our client was incorrectly creating AAFs.
