Latest post Mon, Nov 20 2017 7:54 AM by luca.mg. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Nov 9 2017 2:44 PM
    • Roger Owen
    • Joined on Wed, Jun 21 2006
    • The New Forest, South Coast, UK
    • Posts 58
    • Points 710
    Output to HD Monitor
    I'm catching up with the real world and moving from SD to HD (1080) and would like to output to a HD monitor while editing. My old Mojo can't handle this as it's not HD. My graphics card has an HDMI output but this is not for the 'client monitor'. I'm guessing I will need to replace the SD Mojo with an HD capture card (even thogh I don't need to 'capture' anymore as I am now importing from camera cards. Is there an economical solution that anyone knows? Thanks.
    2 x Avid Xpress Pro 5.x with SDI Mojo, 1 x Avid Xpress DV 4.x, all running on home-built PC's with single core processors. Sony Digibeta and DVcam... [view my complete system specs]
    Lots of kit... only one pair of hands!
  • Thu, Nov 9 2017 3:17 PM In reply to
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 167
    • Points 2,010
    Re: Output to HD Monitor
    You might take a look at the Blackmagic Design series of Decklink cards and Ultrastudio devices.
    The Ultrastudio Mini Monitor is a little device that connects via a thunderbolt connnection and just does HDMI and SDI output...runs about $150.
    The Decklink Mini Monitor is a PC Express card and also just does HDMI and SDI output and runs about $150.
    MC 8.9.1 Dell Precision 7710 mobile workstation, 64GB of memory, Xeon E3-1535M v5 @2.9Ghz, Nvidia Quadro M5000m. Running Win10 64bit. [view my complete system specs]
  • Sat, Nov 11 2017 4:31 PM In reply to
    If you only need HD, not 4K, here's another option:  Search E-Bay and pick up a Matrox Mini (MX02)    They still work great for HD (no 4K) and I've seen quite a few on sale very inexpensively as users upgrade to 4K.
    MC 8.6.1 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Sat, Nov 11 2017 11:39 PM In reply to
    Roger,
    I would go for this, legacy item but still works well with MC 8.
    No HDMI but RGB/YUV to a client monitor.
    https://www.ebay.co.uk/itm/AJA-KONA-3-Video-Capture-Card-WITH-CABLES/222658438836?hash=item33d77a26b4:g:fr0AAOSw2RZZzg7W
    David
    P.S. I have one you can borrow, if you want to check it out.
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona 3. MC 7.0.6 OS 10.9.5 Mac Pro 5.1 2x2.97 6-core 14GB ram Aja I/O express, Apple... [view my complete system specs]
  • Sun, Nov 12 2017 10:31 AM In reply to
    AFAIK the Matrox Mini (MX02) soes not work with Windows 10. It is great for Windows 7.
    MB: ASUS P6TD Deluxe, ATX, Intel X58, QPI 6.4GT/s, Intel LGA1366, 6xDDR3 1600MHz, PCI-E V2.0, On-board Soundkarte. CP: Intel Core i7 920 (2.66 GHz) Quad... [view my complete system specs]
  • Sun, Nov 12 2017 12:21 PM In reply to
    • LKJ JKL
    • Joined on Tue, Jun 2 2009
    • Posts 112
    • Points 1,325
    I like the AJA Io Express.
    Find it here on Ebay uk.
    but I think for Resolve you need to go with a BM solution...
    HP Z420 (E5-1650v2) | 32GB RAM | 250 GB SSD (OS) | NVIDIA Quadro P2000 | internal raid0 | AJA Io Express | Win7 Pro64 Sp1 | MC v8.9.3 [view my complete system specs]
  • Sun, Nov 12 2017 6:08 PM In reply to
    Depending on your motherboard, you might opt for a Thunderbolt device like AJA T-tap (if your conputer has Thunderbolt or if a TB card can be added to it). Very solid.
    Given the choice I’d prefer AJA over BlackMagic Design but the latter also work with Resolve, so that may be helpful.
  • Mon, Nov 20 2017 7:09 AM In reply to
    • werick
    • Joined on Wed, Nov 8 2017
    • Posts 6
    • Points 40
    I have Matrox Mini MX02 and it works fine, though it doesn't have an Expresscard to connect to a laptop.
  • Mon, Nov 20 2017 7:54 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,057
    • Points 59,540
    I gave up the MX02 since it's EOL. Took a Black Magic Intensity Pro 4k, works fine with the latest driver.
    MC 8.8, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
