Latest post Wed, Dec 6 2017 3:58 PM by jef. 12 replies.
Page 1 of 1 (13 items)
  • Tue, Nov 7 2017 5:33 PM
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,177
    • Points 38,575
    8.9.3 / 8.5.3 Safe Color Limiter effect bug
    I have been testing MC 8.9.3.  Ran into a recurring bug.
    FYI - I work in a shared storage environment.
    I set up a sequence in 8.9.3.  Top layer is the Safe Color Limiter effect.  I set my normal settings.  Confirmed that it was working as expected on external scopes.
    Then facility needs changed.  I went to a different room running 8.5.3 (our current house standard).  I opened the sequence created in 8.9.3 and prepared to do an AMA Export / op1a.
    Spot checked my sequence and noticed that black levels were now being clipped at around 20 ire!!
    I opened the Safe Color Limiter effect and all settings were where they should be.  I tossed this effect and redid it in the currently open 8.5.3 system.  Levels were now correct.  I am currently creating the file to go to QC.
    This issue of the Safe Color Limiter effect in a sequence not working correctly between software versions and even PC / Mac systems has come up several times.
    Quite boring.
    Jef
    Avid DS 11.0.2 R.I.P | MC 8.5.3 / 8.9.4 | OS 10.11.x - various MacPro Towers - home system MacPro Dual 2.8 8core GTX680 "Harpertown" QT 10.0... [view my complete system specs]
    Jef Huey
  • Wed, Nov 8 2017 12:37 AM In reply to
    • N Ryan
    • Joined on Thu, Jul 3 2014
    • Melbourne, Australia
    • Posts 71
    • Points 885
    Re: 8.9.3 / 8.5.3 Safe Color Limiter effect bug
    Just wanted to check something, Jef.
    I recently moved from 8.5.3 to 8.6.5 and found issues with some (not all) grades done before the upgrade.
    After some testing, it was found that SOME LUTs were being treated differently in the two versions. In particular, it was the 10bit LUTs applied to the Sony 10bit profiles. The Sony 8bit LUT was fine and the XDCam footage was also fine.
    Are you sure your issue is the Safe Color Limiter, and not a problem similar to mine, with LUTs?
    Cheers,
    OS 10.11.4 Mac Pro Media Composer 8.6.5 with Symphony & Interplay 3.4 AvidFX 6.4 Neat Video 4.1.4 ISIS5500 [view my complete system specs]
    Neil.
  • Wed, Nov 8 2017 3:40 AM In reply to
    • jef
    • Maryland
    • Posts 3,177
    • Points 38,575
    Different problem I believe.  There is a known issue with LUTs acting differently between versions.  Can not tell you off the top of my head what those versions are though.
    Jef
    Jef Huey
  • Wed, Nov 8 2017 3:54 PM In reply to
    • Posts 9,048
    • Points 203,535
    jef:
    I have been testing MC 8.9.3.  Ran into a recurring bug. FYI - I work in a shared storage environment.
    Quite boring.
    Jef
    Jef - I have support looking at this now....  Case # 03327496. I used both your email addresses on the case so you get the scoop and also added myself so I can follow it.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Nov 9 2017 3:11 AM In reply to
    • jef
    • Maryland
    • Posts 3,177
    • Points 38,575
    Thanks M&M,
    I have sent the requested info off to support.
    Jef
    Jef Huey
  • Fri, Nov 10 2017 3:52 PM In reply to
    • Posts 9,048
    • Points 203,535
    Perfect... I got it as well as I am following the case with you... :)
  • Tue, Dec 5 2017 9:34 PM In reply to
    • JDerringer
    • Joined on Wed, Mar 26 2014
    • Posts 4
    • Points 70
    Hi Marianna and Jef!
    Just wanted to check in and see if this issue has been resolved as I'm also seeing the bug where a Safe Color Limiter effect that I've used successully for years is now lifting the bottom 20% or so of the signal.
    If this information helps your engineers at all, in my case both Avid systems were on 8.5.3, Mac OS X 10.10.5, but the effect only functions properly on one of the systems. When I'm back at that edit bay, I can double check all the other specifics - what I/O is being used, etc. But for now I just wanted to see if you've gotten anywhere as this is a big one for us.
    Thanks in advance and hope all is well with you, Marianna!
    Jeremy
  • Tue, Dec 5 2017 10:00 PM In reply to
    If I remember correctly, there was an issue with color FX and LUT translating correctly from to 8.5.x. It was fixed in 8.6.x. This means going from 8.4 or earlier to 8.6 or later would be correct.
    Replacing the source or destination with 8.5 version and the color limiter would create wrong levels.
    Solution would be do everything in 8.5 or remove 8.5 from the equation.
  • Tue, Dec 5 2017 10:29 PM In reply to
    • jef
    • Maryland
    • Posts 3,177
    • Points 38,575
    My situation was going from a higher ver to a lower ver.  It was suggested that that was not a recommended procedure.
    Bottom line - in my opionion - is that you should always rebuild the Safe Color effect.  You can use the same numbers, just "make it fresh".
    Jef
    Jef Huey
  • Tue, Dec 5 2017 10:50 PM In reply to
    jef:
    Jef
    If its known as broken then it would be better if current MC versions recognised older safe colour limiter effects and automatically rebuilt them. No cure for going backwards but solvable going forwards.
    ACI Moderator. I'm not employed by Avid or work for them. I just do this in my spare time. Symphony V8.6 / 8.3.1 HP Z400 system [view my complete system specs]
  • Tue, Dec 5 2017 11:46 PM In reply to
    • JDerringer
    • Posts 4
    • Points 70
    Hi. Just wanted to clarify two specifics about what I'm seeing:
    1. I'm using a Safe Color Limiter effect that works fine on 8.5.3 on one system, but not the other. Maybe there's something else triggering the issue, other than just the Avid MC version. If I find anything further on what's causing this, I'll update everyone. And I'll keep checking back in case any of you do.
    2. Even if I recreate the effect using the same values, the issue persists. I actually need to use different numbers for the bottom of the signal to avoid lifting the blacks about 20% or so.
    Jeremy
  • Wed, Dec 6 2017 5:08 AM In reply to
    • N Ryan
    • Posts 71
    • Points 885
    Are the Safe Color Settings set the same on both systems? (NOT the actual Safe Color Limiter effect)
    How are you applying the effect? Is it from a Template effect? If so, what happens if you set the Safe Color Settings with the appropriate values, then add the Safe Color Limiter from the Effects Palette/Image?
    Neil.
  • Wed, Dec 6 2017 3:58 PM In reply to
    • jef
    • Maryland
    • Posts 3,177
    • Points 38,575
    I am curious.  Are the two system both the same OS?  Do they both have the same IO?
    Jef
    Jef Huey
