Latest post Thu, Nov 16 2017 2:38 PM by RalphC. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Nov 7 2017 12:43 PM
    • Agnieszka
    • Joined on Tue, Nov 7 2017
    • Posts 3
    • Points 45
    mc1st window is dead
    I have tried to search for a similar topic, but cannot find one.
    I have just installed MC1st and tried to run it. I started it for the first time through the application manager -like I read I shoudl. I opens showing for a while the small rectangle with information what is initializing (with no errors) then pop ups the full size application window (which is great... so fat at least), but then... everything is dead, no clicks work, no answer, cannot even close the window - have to kill the process via application manager.
    Does anyone knows what is wrong? How can I fix it to run the MC1st?
    If that's important: I try to run it on laptop Asus U36SG with Windows 10.
    Thanks for any help!!
    Agnieszka
    screenshot
    Media Composer First 8.9.3, Asus U36SG Laptop, Windows 10 Home, Intel Core i5 2.5GHz, 8GB RAM, NVIDIA GeForce 610M [view my complete system specs]
  • Tue, Nov 7 2017 2:51 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,512
    • Points 16,490
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: mc1st window is dead
    Hi agnieszkachr,
     Is it running i7/i5/i3 CP? Or better yet complete your profile.Thanks!
    RalphC
    This is a test. Media Composer 8.8 w/Symphony option, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Tue, Nov 7 2017 5:56 PM In reply to
    • Agnieszka
    • Posts 3
    • Points 45
    Seems like my system specs are set now in my profle also...
  • Wed, Nov 8 2017 9:50 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,368
    • Points 43,475
    That laptop has 2 display adapters, the GeForce 610M and the Intel HD 3000. If both are active, then the primary is probably the HD 3000. You should see if you can disable that in the BIOS, and then try MCF again.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
  • Sat, Nov 11 2017 12:53 PM In reply to
    • Agnieszka
    • Posts 3
    • Points 45
    It is impossible in my laptop's BIOS to disable integrated GPU :-). But I was able to change the graphic card that the MC1st will use to the NVIDIA one, and...
    EVERYTHING WORKS GREAT!
    Thanks a lot for your help!!! You are really GREAT!
    Agnieszka
  • Thu, Nov 16 2017 2:38 PM In reply to
    • RalphC
    • Posts 1,512
    • Points 16,490
      Avid Employee
    Agnieszka:
     Did you changed it from the Nvidia Control panel?
    RalphC
