Latest post Sat, Nov 18 2017 3:32 PM by RalphC. 8 replies.
Page 1 of 1 (9 items)
  • Mon, Nov 6 2017 11:43 PM
    • frlu
    • Joined on Mon, Nov 6 2017
    • Posts 4
    • Points 60
    App manager stuck on initializing
    Downloaded Composer first and cant get it to run. It says i need to login to application manager. When I start app manager it just says "initializing" and nothing more happens.
    I have updated the app manager, then unistalled everything an downloaded it again, but with the same result. Im running it on mac osx 10.12.6
    I have to say I am a bit dissapointed. Nowhere on the avid homepage does it say you have to run app manager, or even what it is. It just shows a lot of happy pople saying how easy composer first is. This is the "beginner" version, the "first" version people new to avid and video editing are suppost to use. Now I have created like 3 different accounts just to be able to write this post.
    I have tried some different editing softwere to find out what to use at home. With Premiere and DaVinci resolve I just downloaded and started, but not with avid.
  • Tue, Nov 7 2017 2:54 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,631
    • Points 17,925
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: App manager stuck on initializing
    Hi frlu,
      First thing I would check is your firewall settings, be sure that it's not blocking this program.
    RalphC
  • Tue, Nov 7 2017 6:04 PM In reply to
    • frlu
    • Posts 4
    • Points 60
    Nope, dont think thats it. I have allowed all avid programs acces, composer first, app manager, iLook (whatever that is). Also tried turning the firewall off, but nothing changed.
  • Wed, Nov 8 2017 3:46 PM In reply to
    • Posts 9,664
    • Points 211,175
    Hi
    Can we get a glimpse into your system specificiations please?  OS, Computer, what exactly you already have installed.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Nov 9 2017 1:36 AM In reply to
    • tommix
    • Joined on Tue, Oct 14 2008
    • Posts 182
    • Points 2,290
    Same thing with OS X but not Win 10
  • Sat, Nov 11 2017 6:11 PM In reply to
    • frlu
    • Posts 4
    • Points 60
    Mac Book Pro with Sierra 10.12.6. 2,8 GHz Intel Core i5, 8 GB 1600 MHz DDR3
    Sure it´s a bit on the weak side, but the program should at least start ...right?
    I tried a 30 day trial of composer a while back, and that worked. I´m looking to upgrade the computer in the future, but right now i´m just seeking what editing program I want to use.
  • Mon, Nov 13 2017 2:54 PM In reply to
    • Posts 9,664
    • Points 211,175
    Frlu
    The dual core i5 stink for performance especially since the editing application MC | First is derived from the big brother MC.  Not only that but you have a larger OS now with Sierra 10.12.x taking up performance.    The 30 day trial you may have used a while back was a earlier verion such as 8.x and had less functionality.
    Did you check the specifications for MC | First hardware ....
    Does it give you any clue when starting up where it is stopping?  Do you have to force quit?  Does it crash and if so are there any crash logs created?
  • Tue, Nov 14 2017 5:41 PM In reply to
    • frlu
    • Posts 4
    • Points 60
    MC First doesn't start up at all. It just says "log in required", and App Manager is stuck on "initializing"
  • Sat, Nov 18 2017 3:32 PM In reply to
    • RalphC
    • Posts 1,631
    • Points 17,925
      Avid Employee
    Hello frlu,
     Hope this helps.
    • Make sure you have the most current version of Application Manager installed
    • Click on your email address and select "Log Out" then enter your email & password and click Sign In
    • Click "Restart App Manager Helper" in the Preferences tab
    • Click "Clear Cache Files" in the Preferences tab
    RalphC
