Latest post Wed, Feb 7 2018 12:12 AM by srdela. 14 replies.
Page 1 of 1 (15 items)
  • Sat, Nov 4 2017 11:09 AM
    • artisan
    • Joined on Mon, Dec 7 2015
    • Posts 5
    • Points 65
    Media Composer First Crashing
    As per the subject - Sits there on "Initializing Audio Effects" for about 60 seconds then crashes with: "The Application Avid media Compoesr First has quit Unexpectedly"
    OSX - 10.12.6
    Imac - i5 - 16GB
    Reinstalled Media Composer First - Didn't help
    Reapired HDD etc - Didn't help
    I do run pro tools on the same system and have plugins on a separate drive.
    Any ideas please?
    Thanks everyone.
  • Sat, Nov 4 2017 3:07 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,792
    • Points 19,770
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Media Composer First Crashing
    Hi artisan,
      Do you have 3rd party plugins installed? You can try moving the plugins to unused folder Library/Application Support/Avid/Audio/Plug-Ins/ for Mac.  MC|First will support AAX and AVX plugins that are ONLY purchased from the Marketplace.
    RalphC
  • Sat, Nov 4 2017 10:47 PM In reply to
    • artisan
    • Posts 5
    • Points 65
    Hi RalphC,
    Thanks for the info.
    I had a look in the plug-Ins folder and they are all aax plugins. Some were purchased from native instruments and waves however.
    Anyway, I just moved all of the plugins to the unused folder as a test and MC First loaded fine..
    Do I really need to move the non avid marketplace plug-ins to the ununsed folder every time I intend to use MC First?
    Why doesn't MC First simply ignore the plugins that it can't use instead of crashing?
    The goal is to puchrase the full MC version but I can't do that without at least editing on First for a little while just to test it out.
    Thanks again.
  • Sat, Nov 11 2017 12:30 PM In reply to
    • artisan
    • Posts 5
    • Points 65
    So I've tried it on the PC and now have a different issue.
    FatalExcpt Exception: Can't create a directory, as one of the folders in the path below has insufficient permissions.
    It points to a G:\ directory which used to be the google drive... That's no longer there.. It seems I've tried MC on this pc before and would sync to google drive..
    I see the G:\ path in the "Managed AMA Media Folders" file which I moved and reinstalled MC First but to no avail.
    Can someone help me get this editor working please? Really frustrating...
  • Sat, Dec 2 2017 2:25 AM In reply to
    • Dennis
    • Joined on Sun, Sep 13 2015
    • Acworth Georgia
    • Posts 6
    • Points 50
    Can you clarify please?
    The previous version of MCF worked with my 3rd party AAX plug-ins not purchased from the Marketplace, are you saying that the latest version is different in that aspect?
    Dennis
    Custom Win 7 i7-4790K 4Ghz 16GB Ram Avid Pro Tools 8.5 Avid Media Composer First 8.8.5 [view my complete system specs]
  • Tue, Jan 16 2018 7:36 AM In reply to
    • Zenboy21
    • Joined on Tue, Jan 16 2018
    • Posts 3
    • Points 35
    Hey, I have a similar problem.
    Media Composer First keeps hanging on "Initializing Audio Effects", and nothing else happens.  When I run the task manager, it says "Not Responding."
    Any ideas?
    Thanks.
    MacBook Pro
    OSX: 10.13.2
  • Tue, Jan 16 2018 8:19 PM In reply to
    • Posts 10,079
    • Points 216,475
    Artisan
    Do I really need to move the non avid marketplace plug-ins to the ununsed folder every time I intend to use MC First?  Why doesn't MC First simply ignore the plugins that it can't use instead of crashing? "
    MC | First is derived from the big MC so much of the same code applies which is why it lets you go from the free version to the commercial ersion without a hiccup.  I suggest you name then a certian way so that you drop the folder in when you want to use PT and when you want to use MC First.
    "  The goal is to puchrase the full MC version but I can't do that without at least editing on First for a little while just to test it out."
    You can test it out but you cant use all the plug in's that are not compaitible with it right now....  I can send you a 30 day temp of the MC comercial if you like to make it easier to test.
    Let me know.
  • Tue, Jan 16 2018 8:20 PM In reply to
    • Posts 10,079
    • Points 216,475
    Check your plug in folder.  My take like Ralph suggested above is you have an incompatible plug in or more than one
  • Tue, Jan 16 2018 8:32 PM In reply to
    • Dennis
    • Acworth Georgia
    • Posts 6
    • Points 50
    The last update resolved many of the errors I was having. I did have 1 plug in from Ik Multimedia that gave me some issues but I was still able to open sessions. I have dozens of 3rd party AAX plug ins I use with Pro Tools and MCF does not seem to care even though I did not put them in another folder. You just can't access them from MCF.
  • Tue, Jan 16 2018 10:28 PM In reply to
    • Zenboy21
    • Posts 3
    • Points 35
    Marianna:
    Thanks. I actually deleted ALL the plugins before I re-installed MCF, but I'm still having the same issue...
  • Tue, Jan 16 2018 11:30 PM In reply to
    • Posts 10,079
    • Points 216,475
    what is the exact error?
    and can you provide your complete system specifications?
  • Wed, Jan 17 2018 5:04 AM In reply to
    • artisan
    • Posts 5
    • Points 65
    Hi - Thanks for the reply.
    I haven't had a chance to play with MC | First more as I had to start editing without issues and moved to another editor which has been wroking flawlessly. I did enjoy the Avid interface so will start on it again after this project is complete.
    The 30day trial code sounds good for MC.
    Thank you again for your help.
  • Wed, Jan 17 2018 5:19 PM In reply to
    • Posts 10,079
    • Points 216,475
    Artisan
    when ready email me and I can get you a 30 day temp.
  • Thu, Jan 18 2018 12:00 AM In reply to
    • Zenboy21
    • Posts 3
    • Points 35
    So I rechecked the plugins folder, and it looks like MCF imported a lot of my music program plugins, including Sample Tank and Amplitube, and a few others.  I moved them back to Library/Audio/Plugins, and MCF started right up!
    Thanks!
    max
  • Wed, Feb 7 2018 12:12 AM In reply to
    • srdela
    • Joined on Tue, Jan 30 2018
    • Posts 2
    • Points 10
    I'm having the same issue. No extraneous plugins that weren't installed with the program. I remember I used to subscribe to the full MC and this was also an issue on a different computer. Never was able to fix it so I just kept using Premiere. Now I'm trying to get back into Avid but I can't even open it. First it was an issue with iLok slowing down my system to a crawl (I changed the service to manual startup, which is the only way I could even get my computer running fine again), and now it hangs on "Initializing Audio Effects". Here's an image of my system info
    https://drive.google.com/open?id=1r2mRDE-gS6Tjhap531NoV-6CLt05Dejp
