Latest post Wed, Feb 14 2018 10:23 AM by Holy_13. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Nov 1 2017 10:41 PM
    • jdrouette
    • Vancouver, Canada
    • Posts 363
    • Points 4,760
    MC 8.9.3 - Markers dialog comments not automatically selected
    My workflow invlolves adding markers with a keyboard shortcut and quickly typing comments in the pop up dialog.
    In MC 8.9.3, the comments field is not automatically selected after creating the marker, so I have to either manually select it with the mouse or toggle through multitle marker dialog elements before reaching the comments box.
    Is this a bug or a deliberate change in functionality? It is slowing me down considerably.
    Avid Media Composer 2018.11 Symphony option, Avid Artist DNxID on macOS 10.14.1, iMac Pro (2017) 10-Core, 3.0GHz Intel Xeon W, Turbo Boost up to 4.5GHz... [view my complete system specs]
  • Wed, Nov 1 2017 11:22 PM In reply to
    Re: MC 8.9.3 - Markers dialog comments not automatically selected
    Have you checked your Marker settings and made sure "Disable Marker pop up when adding" has not been checked. (right click in the Markers Window to access Marker settings)   Typing works with 8.9.2 on W7 after adding Marker from KB.   (Sorry tested with 8.9.2 first.)
    8.9.3 test
    On W10 the Marker pop up window opens from KB add marker but typing does not work without mouse clicking in the popup window.   New project in 8.9.3 and existing Project checked.
  • Wed, Nov 1 2017 11:49 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 363
    • Points 4,760
    AndrewAction:
    Have you checked your Marker settings and made sure "Disable Marker pop up when adding" has not been checked. (right click in the Markers Window to access Marker settings)   Typing works with 8.9.2 on W7 after adding Marker from KB.   (Sorry tested with8.9.2 first.
    8.9.3 test
    Yes, the pop up appears as I want it to, but I can't immediately type unless I click on the comments box. Before 8.9.3, the comments box would activate automatically and I could start typing without any extra clicking.
  • Thu, Nov 2 2017 12:25 AM In reply to
    jdrouette:
    That is what I found with 8.9.3 when I checked it on a W10 machine.
    Edit Add
    Updated a W7 Pro computer from 8.9.2 to 8.9.3.  This machine now has the same issue that I cannot now type in a Marker comment without first clicking in the Marker Dialog box.     (I could 10 minutes this before with 8.9.2 installed)
  • Thu, Nov 2 2017 6:52 AM In reply to
    • TrevorA
    • Posts 1,069
    • Points 12,185
    This behaviour has been intermittent for me for several versions. The marker comment window sometimes has focus, other times not. I have not used 8.9.3 yet
  • Thu, Nov 2 2017 4:25 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 363
    • Points 4,760
    I just got a confirmation from Aleksandra at Avid Customer Care that engineering is aware of the bug and that it will be addressed in v8.10 coming within a month.
  • Thu, Nov 16 2017 5:37 PM In reply to
    • shcuts
    • Joined on Sun, Feb 12 2012
    • Posts 17
    • Points 175
    Thanks for the update. This was making me batty. Especially since I'm heavily marking footage right now! Big Smile
    • shcuts
    • Posts 17
    • Points 175
    Also, have to click, can't just hit enter on keyboard. Really slows the process down.
    TIP IN THE MEANTIME: Hit TAB three times (I'm on a mac but it gets you there without having to move the mouse and click every time.
    after text entered, TAB TWICE to get to the "okay" button and hit enter to get out.
    Sorry for all the edits.
  • Wed, Feb 14 2018 10:23 AM In reply to
    • Holy_13
    • Joined on Thu, Jan 13 2011
    • Posts 4
    • Points 40
    Pretty annoying.
    But press TAB 3 times --> enter text --> press ALT+ENTER(NUM-Pad)
