Latest post Sun, Aug 19 2018 7:01 PM by benrichardson. 19 replies.
Page 2 of 2 (20 items) < Previous 1 2
  • Fri, Jan 5 2018 2:16 PM In reply to
    Re: Avid MC 8.9.3 and High Sierra Permissions issue
    I suspect that the following issue may be related to this thread (I can't test as it is a student's computer at a distant location). She has OS 10.13.2 (HS) and an SSD with APFS. She's installed Media Composer but gets the following error on launch:
    SYS_ERROR, OSErr:-5000.
    Certainly looks like a permissions issue. Is teh Home folder fix likely to work? TIA.
    iMac i5 27", 24GB RAM, OS 10.13.6 with Symphony 2018.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.13.6 with MC 2018.5 and BMD Ultrastudio... [view my complete system specs]
  • Sat, May 12 2018 4:10 PM In reply to
    • Brian Berdan, ACE
    • Joined on Mon, Nov 4 2013
    • Usually Seattle or Los Angeles
    • Posts 68
    • Points 705
    I thought if I created a second partition on my internal drive I could write to it. Instead, though it starts up without the 'no media drive' warning, it crashes when selecting Settings/Media Creation.  I created both a Mac OS Extended and an APFS flavor- both crash.   I'm running MC 2018.3.0, on High Sierra 10.13.4
    It used to be cool to edit on just my laptop with nothing attached!
    2017 MacBook Pro High Sierra 10.13.4 MC 2018.5.0 [view my complete system specs]
  • Sat, May 12 2018 5:17 PM In reply to
    • Brian Berdan, ACE
    • Posts 68
    • Points 705
    Ah, just saw that 2018.5.0 fixes this issue. Installed and works!
  • Thu, May 17 2018 8:15 AM In reply to
    That's great that this is now fixed and works. Thanks for confirming Brian!
  • Sun, Aug 19 2018 7:01 PM In reply to
    I had this same issue with 2018.8, "SYS_ERROR, OSErr:-5000"
    In my case it was the folder Users/Shared/AvidMediaComposer which needed Read & Write permission for "Everyone."
    I was unable to change the permissions using the Finder Get Info window, but was able to use the terminal command, sudo chmod -R 0777 /Users/Shared/AvidMediaComposer   Media Composer now launches successfully.
