Latest post Mon, Oct 30 2017 7:41 AM by DStone. 2 replies.
  • Mon, Oct 30 2017 12:59 AM
    • Ssnygg
    • Joined on Tue, Apr 11 2006
    • Allentown PA
    • Posts 316
    • Points 3,775
    Won't play nice with 4k screen
    I'm in a situation where I have to edit on a 4k laptop.  In avid, the text is beyond miniscule and some of the windows overlap each other in a way that makes them illegible.  Is there a solution for this?  (editing with 8.8.5 but I think I'm licensed to upgrade to current)
    Thanks.
    I have several systems. 1-Media Composer ver 7 1-Media Composer 8.8.4 1-mac Express 2.2 AB/VB Targa set up The computers I use include: 1-Intel core i7... [view my complete system specs]
  • Mon, Oct 30 2017 1:57 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,512
    • Points 58,985
    Re: Won't play nice with 4k screen
    Try the latest version and see if that helps. Avid made some changes recently that will help. Hopefully someone will chime in with experience in the event that there is an additional Windows setting required (you would have to be running the latest Windows 10 Pro probably). Good luck.
    Camera(s) PXW-X70, HDR-FX1, Hero 3+ | MC 18.2 | QT 7.7.9 | BCC 11 | Sapphire 11 | Mocha Pro 5.5.2 | Titler Pro 6 | Windows 10 Pro x64 | System: P6X58D... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Oct 30 2017 7:41 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,331
    • Points 43,095
    4k window support was added with the latest versionS of MC. Also see this post If the text ends up blurry.
    http://community.avid.com/forums/p/179810/845957.aspx#845957
    You could even try that on your current version. I never got around to checking it out on earlier versions ou'd MC.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
