Latest post Thu, Nov 2 2017 10:44 PM by alexfx. 4 replies.
  • Fri, Oct 27 2017 5:10 AM
    • alexfx
    • Joined on Fri, Oct 27 2017
    • Posts 12
    • Points 110
    CheckInAAF via python
    Hello,
    I'm attempting to call CheckinAAF. Via soapui I am successful using MTOM. Via python with the Zeep module it seems MTOM is not supported so I'm trying to base64 encode the AAF, which fails with
    Fault: An unexpected error occurred checking in asset to interplay://AvidWG/Projects/02/Del_test/AlexTest  XML returned from getMetadata is empty Filename=C:\Program Files\Avid\Interplay Web Services\.\apache-tomcat\temp\md_7465657294711782608.tmp.
    Searching around has yielded little information on this error or MTOM attachments with a SOAP python client. Has anyone successfully done this?
    Cheers,
    Alex
  • Fri, Oct 27 2017 8:23 PM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 190
    • Points 2,365
    • Avid Developer Moderator
      Avid Employee
    Re: CheckInAAF via python
    Hi Alex,
    The error you see typically means that payload has not been parsed correctly thus temporary file is empty.
    Please share raw request from the succesfull SoapUI attempt for review.
  • Sun, Oct 29 2017 8:34 PM In reply to
    • alexfx
    • Posts 12
    • Points 110
    Hi Vadym,
    Here is a successful raw request.
    POST http://mca-tv-av-sv01/services/Assets HTTP/1.1
    Accept-Encoding: gzip,deflate
    Content-Type: multipart/related; type="application/xop+xml"; start="<rootpart@soapui.org>"; start-info="text/xml"; boundary="----=_Part_0_71082943.1509306529311"
    SOAPAction: ""
    MIME-Version: 1.0
    Content-Length: 630441
    Host: mca-tv-av-sv01
    Connection: Keep-Alive
    User-Agent: Apache-HttpClient/4.1.1 (java 1.5)
    ------=_Part_0_71082943.1509306529311
    Content-Type: application/xop+xml; charset=UTF-8; type="text/xml"
    Content-Transfer-Encoding: 8bit
    Content-ID: <rootpart@soapui.org>
    <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:typ="http://avid.com/interplay/ws/assets/types">
       <soapenv:Header>
          <typ:UserCredentials>
             <typ:Username>*****</typ:Username>
             <typ:Password>*****</typ:Password>
          </typ:UserCredentials>
       </soapenv:Header>
       <soapenv:Body>
          <typ:CheckInAAF>
             <typ:InterplayURI>interplay://AvidWG/Projects/02/Del_test/AlexTest</typ:InterplayURI>
             <typ:AAF><inc:Include href="cid:TEST.aaf" xmlns:inc="http://www.w3.org/2004/08/xop/include"/></typ:AAF>
          </typ:CheckInAAF>
       </soapenv:Body>
    </soapenv:Envelope>
    Content-Type: application/octet-stream; name=TEST.aaf
    Content-Transfer-Encoding: binary
    Content-ID: <TEST.aaf>
    Content-Disposition: attachment; name="TEST.aaf"; filename="TEST.aaf"
    ��ࡱ�AAFB
  • Mon, Oct 30 2017 11:29 PM In reply to
    • Vadym
    • Posts 190
    • Points 2,365
      Avid Employee
    Thanks Alex,
    So what you mean is that the module you're using doesn't have MTOM encoding? Then use plain request or another module with MTOM support.
  • Thu, Nov 2 2017 10:44 PM In reply to
    • alexfx
    • Posts 12
    • Points 110
    I managed to get MTOM encoding working with the python module I'm using (Zeep) with a little tweaking. Thanks!
