Latest post Wed, Jan 3 2018 11:31 AM by Laur. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Oct 26 2017 8:49 AM
    • Laur
    • Joined on Tue, Mar 20 2012
    • Bucharest - Romania
    • Posts 19
    • Points 215
    waveform not displaying after AMA LINK-render audio effect
    Basically I don't see the waveform anymore after I render for example the Maxim audio effect (and NugenLM Correct 2 also), using the AMA Link method. Tried to create another project/user. No success. On file import, everything works. Is there an option to enable?
    Thank you!
    screenshot
  • Thu, Oct 26 2017 9:03 AM In reply to
    • Laur
    • Posts 19
    • Points 215
    Re: waveform not displaying after AMA LINK-render audio effect
    Later edit.
    Tried on 2 MAC PRO machines with the same specs/configs and on one Windows 10 machine (asus rog)
  • Thu, Oct 26 2017 10:40 AM In reply to
    I've often found AMA sources won't display waveforms. ot sure if its the type of file and how the Audio is handled.
    A transcode of just the audio normally works.
  • Thu, Oct 26 2017 10:43 AM In reply to
    • Laur
    • Posts 19
    • Points 215
    this is the first time when it happens. AND after upgrading (clean install) to the latest version.
  • Thu, Oct 26 2017 12:00 PM In reply to
    • Laur
    • Posts 19
    • Points 215
    tried with 8.9.1
    with this version I can see the waveform when AMA Linking - applying an audio effect+render.
    so it's an issue with 8.9.2
  • Thu, Nov 16 2017 10:45 AM In reply to
    • Laur
    • Posts 19
    • Points 215
    8.9.3 also.
    Prores 422 on timeline.
    apply Gain Effect - render - no waveform
    apply Maxim effect - render - no waveform
    Tried on 3 machines - Mac/Windows10
  • Wed, Nov 29 2017 4:41 PM In reply to
    • Laur
    • Posts 19
    • Points 215
    no one getting this issue?
  • Wed, Nov 29 2017 9:37 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,610
    • Points 60,240
    Does this happen with other media types ?
    I just tried Maxim (AudioSuite clip effect) on XAVC-L material without issue.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.11 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64 |... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Fri, Dec 1 2017 7:14 AM In reply to
    From the image you posted waveforms are not enabled.
    For better help you should update your specs.
    Desktop PC
    3 Heads Digital Films
  • Fri, Dec 1 2017 1:59 PM In reply to
    Waveforms can be enabled from the timeline fast menu as well as the track control panel.
  • Fri, Dec 1 2017 5:03 PM In reply to
    • sthomas
    • Joined on Thu, Jan 22 2015
    • Charleston, SC
    • Posts 3
    • Points 35
    Having the same problem. Lately, been forced to consolidate/transcode, import or create an audio mixdown.
    I'm running 8.9.3 on Mac 10.12.6 working primarily with Red footage. Would love for this to get fixed!
    Late 2013 model Mac Pro 3.7GHz quad-core Xeon/32GB & Late 2013 model MacBook Pro Retina 2.3 GHz quad-core i7/16GB [view my complete system specs]
  • Wed, Jan 3 2018 11:31 AM In reply to
    • Laur
    • Posts 19
    • Points 215
    Curious about the 8.10 release...
