Latest post Sun, Nov 5 2017 9:49 PM by mkj. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Oct 23 2017 9:46 PM
    • mkj
    • Sweden
    • Posts 359
    • Points 4,710
    A show with many episodes...in only one project?
    I have seen many productions creating a separate Avid Project for each episode of a show. Is there any reason to do so?
    Is it not smartest to have everything in same project and just create folders inside of that instead?
    How would you arrange a project like for example Survicor with 40 episodes?
  • Tue, Oct 24 2017 3:35 PM In reply to
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 183
    • Points 2,180
    Re: A show with many episodes...in only one project?
    I would also suspect that the reason for this for episodic television is workflow. They may have several different people working on a given episode at different stages. An assistant editor may create the initial project, ingest and organize footage, create dalies, etc... this is then handed off to an editor to craft the episode. This then might be passed off to others to do other finishing work.
    Meanwhile the assistant editor is already working the next episode in a new project and the process continues.
    Not to mention that there may be several editors working on different episodes at same time.
    In any event, probably a good idea to not have all your eggs in one basket. If the Avid project gets corrupted, then you lose a lot.
    You can import bins from other projects into another projects. Copies of common media, such as opening titles, graphics,etc.., can also be on a drive.
    MC 2018.4 Dell Precision 7710 mobile workstation, 64GB of memory, Xeon E3-1535M v5 @2.9Ghz, Nvidia Quadro M5000m. Running Win10 64bit. MC 2018.5 Asus... [view my complete system specs]
  • Tue, Oct 24 2017 4:29 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 440
    • Points 5,185
    i build huge projects on a regular basis.
    for me the differentiator between mega projects and one-off projects is how much you intercut.
    I have customers where i have only a single project built over years and years. lots of repurposing old interviews.
    i have documentary series that don't really share any media except for graphics. single projects.
    I don't see how an avid project getting corrupted is of any danger.
    recreate with the same name, done imho.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Wed, Oct 25 2017 12:45 AM In reply to
    When I am working on a series I like to have everything on one project no matter how many episodes.
    I've done 35-40 episodes (with 8-10 hours of shootings not more) on the same HD project (DNxHD36)
    with absolutely no problem. Always having the project backed up on another big HDD.
    MC proved worth trusty and I never forget that.
    Desktop
    Corsair RM750X/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.4/Corsair 32G DDR3/PNY Quadro P2000D(390.77)/Samsung 850 Pro SSD(OS) 256 GB/ 2x2TB WD RE4@RAID 0/LG BH16NS40/W10 Pro 64bit/Media Composer Software 2018.7 with Symphony Option/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Wed, Oct 25 2017 6:41 AM In reply to
    While there are other methods as well, creating many projects can help with deletion later on. If you use the media tool or MDV, creating projects per episode can make media management simpler, especially in combination with shared storage where creating storage locations (workspaces) per episode also helps.
    But a project that has lots of common media and/or flashbacks might be better of with one project.
    It all depends on the project type, the available storage and how experienced the editing team is with media management.
    Jeroen van Eekeres
    www.mediaoffline.com
  • Wed, Oct 25 2017 8:24 AM In reply to
    Avid projects are thjat important, and the main reason Avid is such a powerful NLE tool.
    Its Avid bins that save the creative work. And Avid Attic that keeps old copies for recovery.
    As Jeroen says Media created in an Avid Project is tagged by that project name so media management can be made simpler with a project for each episode.
    So it really depends on what you need to achieve. With Avid you can organise it as best suits.
    Personally I'd have projects for each episode and possibly an overall project for shared elements. and then use the shared project to pull bins in and work on.
  • Thu, Oct 26 2017 3:25 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,351
    • Points 62,770
    This question keeps popping up from time to time, and the answer is that it's mostly better to have separate episodes, mainly for media management and prep-cut-post ease, but to each his own.
    Symphony 2018.5, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Thu, Oct 26 2017 6:54 PM In reply to
    • mkj
    • Sweden
    • Posts 359
    • Points 4,710
    one benefit with having everything in one project must be that you can use the Find function in a better way
  • Thu, Oct 26 2017 8:03 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,351
    • Points 62,770
    Upon opening a bin from another project in the current project MC will index that bin, and the clips show up in the search results. Are we talking about local or shared storage?
    peace luca
  • Sun, Nov 5 2017 9:49 PM In reply to
    • mkj
    • Sweden
    • Posts 359
    • Points 4,710
    luca.mg:
    Shared!
