Latest post Tue, May 29 2018 1:19 PM by Marianna. 12 replies.
Page 1 of 1 (13 items)
  • Mon, Oct 23 2017 1:27 PM
    Windows 10 Creator update has made Avid 7.0.3 not run
    I'm running MC 7.0.3 on a surface Pro 4 with no issues until this update that just happened. Anyone have a work around? Or do I have to roll back?
  • Mon, Oct 23 2017 1:31 PM In reply to
    Re: Windows 10 Creator update has made Avid 7.0.3 not run
    MC can run on anything but not qualified for.
    Using an intel HD card to run MC isn't anyway close to that.
    Now if you think that the Windows 10 Cerator has done the damage you should do the rollback
    and keep us updated as well.
    Desktop PC
    3 Heads Digital Films
  • Mon, Oct 23 2017 6:20 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 566
    • Points 7,250
    r0607Ninja:
    Hopefully, rolling back should fix your problem. For the longer term, you need to think about preventing Windows 10 from updating, which isn't as easy as it was in past versions of Windows.  Ideally, you'd take your Surface Pro off the internet (which would also help prevent virus attacks), but more of us are now using our computers for multiple tasks, so this isn't always convenient.
    So, your other alternative is to dive into the Policy Editor or registry settings to disable the automatic updates. Below is a link that discribes the steps involved.
    https://www.windowscentral.com/how-stop-updates-installing-automatically-windows-10
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Mon, Oct 23 2017 6:28 PM In reply to
    Follow that rule in any case.
    Desktop PC
  • Tue, Oct 24 2017 4:52 PM In reply to
    THanks for your help. I will have to roll back, but I do think it's silly that we still accept these issue with Media Composer. I've been running it on this machine fine for years, and other NLE's don't have these common issues.
    Thanks again for your help.
  • Wed, Oct 25 2017 12:35 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,386
    • Points 97,010
    r0607Ninja:
    Sorry, but other NLEs do have "these common issues", and they also happen in the Apple world - possibly even more so there, because Apple will often enforce application changes when they issue an OS update.
    If a software designer builds an application using the rules published by the OS manufacturer then those rules are arbitrarily changed, who's at fault?  The app designer or the OS manufacturer?  I have software that still runs on W10 that was designed and built in the 1980s.  It doesn't need to do much except read and write files and rely on the OS to display the result.  It will probably continue to function as long as Windows exists on Intel x86 style platforms.  But it doesn't have the complexity of an NLE.
    Back when I was developing software in the late '80s/early '90s this type of issue was a problem in the much simpler MS-DOS world, and it remains a problem to this day.  Trust me - no developer is delighted when a driver update or OS change breaks their software.  If you get frustrated, think what they must feel!
  • Tue, May 22 2018 2:03 PM In reply to
    • Don Nelson
    • Joined on Fri, Mar 7 2014
    • Posts 2
    • Points 30
    My Media Composer 7 installation suffered the same fate with the Windows 10 Creator update.  I was comtemplating what to do--rollback the update, buy a newer MC, etc.  But the subsequent update to Windows 10 seems to have resolved the incompatibilities introduced by the previous update.  Without changes to the MC installation, it is running again!  I am running Windows 10 Pro, version 1803, build 17134.48.  If you are still looking for a fix, you might try going to Windows Update and installing the newest version.
  • Tue, May 22 2018 2:18 PM In reply to
    • Don Nelson
    • Posts 2
    • Points 30
    Smile [:)] Re: Windows 10 Creator update has made Avid 7.0.3 not run
    I did not make any changes to MC 7.0.3 after it was disabled by the Windows 10 Creators update.  But now with Windows 10 update 1803, the incompatibilities seem to be resolved and MC runs as it did before.  No longer a need to rollback Windows or upgrade MC to fix the problem!  I am running MC 7.0.3 on Windows 10 Pro version 1803, build 17134.48.
  • Thu, May 24 2018 10:38 PM In reply to
    Anyone having issues installing 7.0.6 on Windows 10?  Or Is it just 7.0.3 that will install on Win 10?  I managed to install it just fine, but I'm having one heck of a time trying to get my license to work.  Just gives me an error:
    "There was an unspecified error (5) initialising the licensing engine"
    I won't even run the 30 day trial.  Previously, I ran MC 8.7 on this machine, but deactivated/moved that license to a newer PC and I wish to use this slightly older PC with MC 7.0.6 as a "B-system" for my assistant.
    When I contacted Avid support the phone tech guy with a thick eastern European accent stated sort of rudely that it wasn't supported on Windows 10, then wouldn't really talk anymore.  So that was that... no help for me.  Hoping the nice people in this community can be more constructive Smile  Any ideas?
    Avid Media Composer 2018.10 MSI GT73VR 6RE Titan SLI Intel i7 Laptop Windows 10 Pro 64GB RAM USB3 media storage BlackMagic Design UltraStudio Mini... [view my complete system specs]
    Jason Spencer, Director/DP/Editor digitallunchbox.com
  • Fri, May 25 2018 1:23 AM In reply to
    "But now with Windows 10 update 1803, the incompatibilities seem to be resolved and MC runs as it did before.  "
    This gives me hope, but my Windows 10 is version 1709, and when I check for new updates it says there aren't any.
    Edit: I just learned how to force updates that MS hasn't sent to users yet. And I'm very happy to report that upgrading to Windows 10 ver. 1809 has fixed whatever issues were causing Media Composer to crash. So I'm working on a Surface Pro 4 8GB Ram running MC 7.07 on Windows 10 ver 1809. And It's running very well.
    Thanks to the user who posted this update, and thanks to auto-email for letting me know!
  • Fri, May 25 2018 12:42 PM In reply to
    • Posts 10,214
    • Points 218,175
    Hello
    Look for the following folder.  If found, delete the entire folder.
                                 C:\ProgramData\Avid\Licenses
    Important:   If you can’t find the specific folder in Windows, go to Folder Options in the Tools menu and select “Show Hidden Folders.”
    marianna
  • Tue, May 29 2018 5:00 AM In reply to
    Marianna... you are the greatest.  Deleting "licenses" folder worked like a charm.  I'm now living in the timewarp known as Media Composer 7. Geeked THANKS!
  • Tue, May 29 2018 1:19 PM In reply to
    • Posts 10,214
    • Points 218,175
    Welcome....  this is exactly what the forums are all about.  Helping others!!!!
    marianna
