Latest post Thu, Oct 26 2017 3:05 PM by DStone. 4 replies.
  • Fri, Oct 20 2017 5:58 AM
    • Scottydog
    • Joined on Thu, Jun 2 2011
    • Posts 3
    • Points 35
    Media Composer - can't find audio interface
    I have just setup Media Composer 8.9.2 on Windows 10.   In audio setup I can't sewither my UA Apollo oe Lynx Aurora as audio interface choices.  Please help in how to do this.  Thanks
  • Fri, Oct 20 2017 5:03 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,368
    • Points 43,475
    Re: Media Composer - can't find audio interface
    Open the MC console and type is 'asiocontrol'. This brings up the ASIO control panel. Depending on your audio setup, this will bring up a generic control panel or a device specific control panel. If there's no ASIO devices, it may bring up the Windows WDM control panel. You may or may not be given a choice of what device to pick from there. Both of your audio interfaces should be ASIO compliant.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
  • Thu, Oct 26 2017 6:55 AM In reply to
    • Scottydog
    • Posts 3
    • Points 35
    Thanks Dave - I've  done this with  each  of  these, but neither play audio from timeline. Both are fine in Protools on same machine.  What am I missing?
  • Thu, Oct 26 2017 7:14 AM In reply to
    • Scottydog
    • Posts 3
    • Points 35
    Ok I have the Apollo. I had to disable/remove the built in audio in the asio panel.  Now when I open MC, there is no composer window.  Yikes  None of these problems on the Mac, but our Windows machine is way more powerful.
  • Thu, Oct 26 2017 3:05 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,368
    • Points 43,475
    MC Giveth, and MC Taketh Away!!
    If disabling the audio input gets the Apollo to work, then it sounds like a driver issue. Here's where you may want to contact the manufacturer for each of your I/O boxes. It may be that there are known incompatibilities. If they have user forums, try perusing them as well.
    Unfortunately, it's very difficult to diagnose a hardware related issue without having the actual hardware. Pretty much any ASIO compatible box should work, but with all the changes made for the Avid branded 3rd party I/O boxes, who knows what is and isn't currently compatible.
    Dave S.
