Latest post Sat, Jun 2 2018 5:02 PM by Terry Snyder. 12 replies.
Page 1 of 1 (13 items)
  • Wed, Oct 18 2017 11:32 AM
    • LKJ JKL
    • Joined on Tue, Jun 2 2009
    • Posts 128
    • Points 1,485
    NVIDIA Quadro / Z420 Questions
    In my HP Z420 [E5-1650v2], I want to replace my old NVIDIA Quadro 2000D card.
    If I want to stick with a Quadro card and stay in my price range, I see two options:
    - NVIDIA Quadro M2000
    - NVIDIA Quadro P2000
    (They cost roughly the same. And of course I would prefer the newer and more powerful P2000.)
    Now I have these questions:
    1. Is the P2000 compatible with the Z420?
    2. Do I have to buy the HP branded version of the P2000 card - or is it ok to buy the PNY NVIDIA Quadro P2000?
    Any other suggestions regarding a new graphics card are very appreciated, too.
    TIA
    HP Z420 (E5-1650v2) | 32GB RAM | 250 GB SSD (OS) | NVIDIA Quadro P2000 | internal raid0 | AJA Io Express | Win7 Pro64 Sp1 | MC 2018.11 [view my complete system specs]
  • Wed, Oct 18 2017 12:54 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 169
    • Points 2,025
    Re: NVIDIA Quadro / Z420 Questions
    I am using a P2000  with Windows 10 - using asus prime MB (Z270) & I7 -  without any problems.  I used the the specified driver in 8.9.1 for the video card.
    Symphony 2018.12 - Win 10 pro, Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,64gig memory, 500gig SSD system drive, WD 5TB,and 2TB media, BM Intensity... [view my complete system specs]
  • Wed, Oct 18 2017 12:58 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 537
    • Points 6,845
    LKJ JKL:
    I'm pretty sure the P2000 would be fine with the Z420, as I've never heard of any modern Quadro card not being compatible with HP products, and I'm sure they would never force you to buy HP branded versions over a PNY version.
    Whatever card you decide on, I would recommend you get the version that expells the cooling air out of the back of the card (as in the 'founders'edition cards) rather than blowing hot air inside the workstation.
    With all the new cards that are coming out, it's hard for Avid to keep an up-to-date list of compatible cards, but many of us have found that with the latest versions of MC, most modern cards work fine.
    Unless things have changed recently, Avid have never really fully utilised the power of modern cards, and it's things like Boris and Sapphire plugins that seem to benefit most from lots GPU muscle. If you're also going to be running other software that loves lots of GPU power (like Davinci Resolve) then it's sensible to go for the best you can afford.
    If you go to the following link....
    http://www.nvidia.com/object/avid-media-composer.html
    ... it would seem to suggest that as far as Nvidia are concerned, the P2000 should be fine with MC
    HP Z800, HP8760, SonnetFusion RAID, Mojo DX, Symphony 8.10, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Wed, Oct 18 2017 3:02 PM In reply to
    • Posts 10,011
    • Points 215,650
    Also.......
    Just take note that very old quadro series cards no longer work with the latest Nvidia drivers (385.08). P2000 - you are good!!!!!!!!!
    Quadro Series:
    Quadro GP100, Quadro P6000, Quadro P5000, Quadro P4000, Quadro P2000, Quadro P1000, Quadro P600, Quadro P400, Quadro M6000 24GB, Quadro M6000, Quadro M5000, Quadro M4000, Quadro M2000, Quadro K6000, Quadro K5200, Quadro K5000, Quadro K4000, Quadro K4200, Quadro K2200, Quadro K2000, Quadro K2000D, Quadro K1200, Quadro K620, Quadro K600, Quadro K420, Quadro 410
    Quadro Series (Notebooks):
    Quadro P5000, Quadro P4000, Quadro P3000, Quadro M5500, Quadro M5000M, Quadro M4000M, Quadro M3000M, Quadro M2000M, Quadro M1000M, Quadro K5100M, Quadro K5000M, Quadro K4100M, Quadro K4000M, Quadro K3100M, Quadro K2200M, Quadro K2100M, Quadro K3000M, Quadro K2000M, Quadro K1100M, Quadro K1000M, Quadro K620M, Quadro K610M, Quadro K510M
  • Wed, Oct 18 2017 5:28 PM In reply to
    • LKJ JKL
    • Posts 128
    • Points 1,485
    Thank you so much for your input - this is very helpful for me!:)
    I did some further investigations which confirm that (1) the P2000 fits well into the Z420, and (2) the PNY is fine, too.
    @Marianna - so the NVIDIA Quadro 2000D (which is not on the list) is no longer recommended/working with Avid? Did I get this right?
    Because... I never had such a sloppy Avid installation... The same system worked ok with MC 7x versions.
    It would be great if my old Quadro 2000D is the only culprit!
    @Bruno
    "I would recommend you get the version that expells the cooling air out of the back of the card (as in the 'founders'edition cards) rather than blowing hot air inside the workstation."
    I only found P2000 cards with the fan on the bottom of the card.
    Like this:
    p2000
  • Wed, Oct 18 2017 6:05 PM In reply to
    I bought a PNY P2000 to replace my old PNY 2000D which is still working on 8.9.2 by 353.82 driver (any problem isnt Avid's but Nvidia EOL them).
    However it seems that this P2000 card was faulty and I sent it back after try it to my (old) PC (and at other newer two at a computer store) as it never gave any signal (of life). Waiting for a replacement.
    First time I see a card not working. Anyways I think if the card is ok you will never have any problem with it as I have never had (till today) any issue with my old (too) 2000D.
    Just my two euros.
    Desktop PC
    3 Heads Digital Films
  • Thu, Oct 19 2017 7:06 AM In reply to
    • Bruno M
    • London, UK
    • Posts 537
    • Points 6,845
    LKJ JKL:
    Like this:
    p2000
    Yes, I can see this. It was only a recommendation when using some of the heavyweight cards which throw out around 300 watts of heat, and can really raise the temperatures inside your workstation.
    The P2000 specs say it only consumes 75 watts which isn't going to be such a problem.
  • Thu, Oct 19 2017 9:40 AM In reply to
    • LKJ JKL
    • Posts 128
    • Points 1,485
    ah ok, thanksSmile
  • Fri, Jun 1 2018 5:32 AM In reply to
    If I put a P5000/6000 into my Lenovo P900 along with my existing M4000 and have the M4000 running the displays so the P6000 would be fully dedicated to graphics processing, would that get along with MC?
    Lenovo P710 Windows 10 Pro Dual Xeon E5-2643 v4 3.4GHz (6-core) 64 GB RAM NVIDIA M4000 [view my complete system specs]
  • Fri, Jun 1 2018 9:16 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 465
    • Points 5,475
    nope, MC only uses the display gpu.
    sapphire might.
    multi gpu not worth it unless: big resolve setup.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Sat, Jun 2 2018 3:58 AM In reply to
    What I meant was, will MC freak out? It used to be very sensitive to hardware config.
  • Sat, Jun 2 2018 8:24 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 465
    • Points 5,475
    nope, MC won't look, won't care.
  • Sat, Jun 2 2018 5:02 PM In reply to
    Over the years, I have used low-end Quadro cards (meeting MC's minimum requirements) and have upgraded to expensive Quadro cards.  I've never noticed any increased performace with the more expensive Quadro cards when running MC.   But, as the others have said, I do see a difference running other programs.
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
