Latest post Wed, Oct 18 2017 11:26 PM by touviere7. 3 replies.
  • Tue, Oct 17 2017 1:43 PM
    • iliagin
    • Joined on Tue, Oct 17 2017
    • Posts 3
    • Points 35
    Fail transcoding GH3 Panasonic footage
    while browsing through the forum I saw that this's quite an old Avid issue, but I haven't seen any recent thread about it, so I hope that there's a solution.
    I'm using the latest version of Avid (8.9.2). I have a footage from GH3 Panasonic camera, which I need to bring into a project most of which was shot with Sony FS7 in 3840x2160. While there were not any problems linking and transcoding Sony's footage, the one from Panasonic doesn't work. After linking the footage, each time I try to transcode Avid freezes after 10 seconds. I tried to open separate project with the right format for Panasonic, but with no luck... I've installed Panasonic plug-in, but in Source window I could not find the option for it (it detected as AVCHD and it impossible to change it). Importing the files is working, but I prefer transcoding (as far as I know, it's better or am I wrong?), is there any way to transcode GH3 footage?
    Thanks!
  • Tue, Oct 17 2017 11:10 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 578
    • Points 6,520
    Re: Fail transcoding GH3 Panasonic footage
    if avchd files, try to rewrap the files into .mov and that should do the trick
    cliptoolz convert v4 or dali's mustache works great for that.
    make sure you select an audio codec other that the original!
    mc 2018.8 with symphony - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (398.36) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2... [view my complete system specs]
  • Wed, Oct 18 2017 5:48 PM In reply to
    • iliagin
    • Posts 3
    • Points 35
    But if I convert the video wouldn't it hurt its original quality?
  • Wed, Oct 18 2017 11:26 PM In reply to
    • touviere7
    • los angeles
    • Posts 578
    • Points 6,520
    rewraping the files would not alter the video at all.
    my experience with lumix avchd files was a problem with audio, that's why i recommended to use another codec than the original.
    both apps mentioned work the same way.
    in video codec pulldown menu, choose  wrap to mov
    in audio codec pulldown, choose 48k 16 or 24bit for example
