Latest post Thu, Oct 19 2017 5:00 PM by Dan_B. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Oct 12 2017 7:07 PM
    • EvanAA
    • Joined on Mon, Mar 7 2016
    • Posts 38
    • Points 495
    Avid Export help. I'm not a new kid
    Hi All,
    I mostly do color correction. Doing it on Resolve, Avid Symphony, Premiere.
    Like a lot of Resolve colorist have moved to PC.
    So here is the issue. Still need to deliver ProREsHQ mostly.
    Many of my deliverables need 6 or even 10 tracks audio.
    So workflow has been in Avid to do a Mixdown to 175x and have the audio tracks needed at it's own Seq.
    This let's me do a Same As Source (175x) and also let's me set audio to DirectOut. As far as I know this is the only way from Avid to export multi  audio tracks.
    Now the tricky part. taking that file and making a Legitimate ProResHQ file. The rub is. Adobe/Premiere/Media encoder don't read DnX levels right. So I can't just throw it into encoder on a MAC and set it up. Yes I can put it into Premiere and then throw a "levels" EFX and tweak that then export.
    YES I have looked into the few "non-oficail" ProREs makers. there are issues there i don't need to get into.
    So any thought?
    evan
  • Fri, Oct 13 2017 8:10 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 474
    • Points 6,000
    Re: Avid Export help. I'm not a new kid
    Hi Evan,
    I was going to point you over to the discussions on Lift Gamma Gain but then realised you'd been involved in those!
    Bruno
    HP Z800,HP8600,HP8760WSonnetFusion RAID, Mediadock U320, Classic Nitris Mojo DXSymphony 5,6 & 8.5 JVC DTV1910 HD tube monitor, HP Dreamcolor, [view my complete system specs]
  • Fri, Oct 13 2017 9:36 AM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 430
    • Points 5,005
    rhozet promedia carbon does a solid implementation of prores on PC.
    maxes out at 422 HQ
    also quite quite expensive.
    can send you testfile.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Fri, Oct 13 2017 1:23 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,358
    • Points 43,355
    I use FootageStudio from Acrovid.com. It support Prores up to 444 and 8 channels of audio. There's a trial version available and it's relatively inexpensive. To be honest, I mostly use it for the video denoising function, but the conversions I've done with it have all come out well.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
  • Tue, Oct 17 2017 2:55 PM In reply to
    • ramz434
    • Long Island
    • Posts 170
    • Points 2,125
    Spitballing here - but can you open up the DNX file in QT on a Mac and export as ProRes. I've done this for delivery before and its worked out well. Seems to be pretty much just a re-wrap.
    I know you're on a PC now, but you said "The rub is. Adobe/Premiere/Media encoder don't read DnX levels right. So I can't just throw it into encoder on a MAC and set it up." - so didnt know if you had access to a Mac.
    - HP Z400/24gb ram/Windows 10/MC8.9.4/256gb Samsung SSD/ NVidia GTX 1080/HP ZR22 Monitors/ - Macbook Pro/16gb ram/OS 10.13/MC8.9.4/NVIDIA GeForce... [view my complete system specs]
  • Thu, Oct 19 2017 3:43 PM In reply to
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 176
    • Points 2,105
    Avid works in "video" level what Avid refers to as "legal" while media encoder and premiere are probably expecting "data level" or as Avid calls "full", right?
    If you export from Avid as "scaled from legal to full" and then pull it into media encoder the levels should appear correct, no?
    MC 2018.4 Dell Precision 7710 mobile workstation, 64GB of memory, Xeon E3-1535M v5 @2.9Ghz, Nvidia Quadro M5000m. Running Win10 64bit. MC 2018.5 Asus... [view my complete system specs]
  • Thu, Oct 19 2017 5:00 PM In reply to
    • Dan_B
    • Joined on Tue, Nov 26 2013
    • Posts 143
    • Points 1,560
    My advice would be to link in the DNX file in a Mac avid system, transcdoe to Pro Res 422 HQ, export same as source.
    You know avid is going to read the levels correctly as its come from one.
    Dan
