Latest post Tue, Dec 19 2017 9:21 PM by Doug Abel. 14 replies.
Page 1 of 1 (15 items)
  • Tue, Oct 10 2017 9:55 PM
    • C-King
    • Joined on Tue, Sep 6 2016
    • Posts 29
    • Points 445
    Script search not searching all scripts
    Running MC 8.9.2 on Mac Pro running 10.11.6.
    Working on a sprawling doc project with 100ish hours of interviews and more to come, all transcribed and scripts imported.
    When I keyword search "Current Script" for "Script A" I get multiple hits, but when I search "Scripts in Project", "Script A" doesn't come up, and nor do several others which I know to contain the keyword.
    Is there anything I can do to get it to re-index the scripts without also reindexing the Phrasefind index, which takes a looong time?
    C King
    MC 8.9.1 on 8-Core trashcan Mac Pro, 32GB RAM, 10.11.6, G-RAID Studio XL TB2 RAID MC 8.9.1 on tbMPB15, 16GB, 10.12.4 [view my complete system specs]
  • Wed, Oct 11 2017 3:28 PM In reply to
    • Posts 8,796
    • Points 200,240
    Re: Script search not searching all scripts
    C-king......
    In each Project folder, you shoud see a folder called SearchData which contains a file called _SearchDB_.
    This file is the database of the indexed bins within your project.
    If you have ScriptSync activated, which you do, you should also see a folder called PhoneticData which contains a number of files with a .pat extension; these files contain the phonetic information for each of the audio clips within your project. One .pat file will be created per clip.
    I suggest you delete the _SearchDB_ when MC is NOT running and restart and let SS redo your search.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Oct 12 2017 3:23 PM In reply to
    • C-King
    • Posts 29
    • Points 445
    Thanks Marianna-
    I did that, and waited until the Bin Index light in the search window was all the way green, and repeated the search. This time I used a term that appears in all or nearly all of the 20+ scripts in the project, but only 9 were found in the search. Is the bin index light a reliable indicator that it has finished indexing? Activity monitor shows AvidBinIndexer to be running, but at less than 1% CPU. Meanwhile AvidPhoeneticIndexer seems to run nonstop (200%+ CPU) but never seems to finish, even left running overnight or weekend, and seems to be creating new .pat files for clips that were ingested nearly a year ago.
    Any thoughts? It would be great to be able to have more control and information about the indexing process; for example, to choose which bins I need Phrasefind to index, and a list of which bins/scripts have been indexed.
    Chyld King
    Edit to add: It does find the terms if I search the missing scripts individually; just not in "Scripts in Project" (which would be more helpful).
  • Thu, Oct 12 2017 3:54 PM In reply to
    • Posts 8,796
    • Points 200,240
    Chyld
    Weird as the light shoud be reliable - let me gab with the engineering guys on this one and get back to you soon.
  • Wed, Oct 18 2017 6:30 PM In reply to
    • C-King
    • Posts 29
    • Points 445
    Hi Marianna-
    Any word on this? It seems like some scripts just don't come up in the found window if "scripts in project" is selected, no matter what, though I can search them individually.
    Chyld
  • Fri, Oct 20 2017 12:55 AM In reply to
    • Kristin V.
    • Joined on Tue, Oct 10 2017
    • Posts 1
    • Points 5
    I'm having the same problem. Please share any update info. Thx!
  • Thu, Oct 26 2017 2:06 PM In reply to
    • sunitadee
    • Joined on Thu, Oct 26 2017
    • Posts 1
    • Points 5
    I am also looking for a solution to this same problem! We are working from a server, and for a search term that I know appears in many of our scripts I get 17 results while my AE (working in the same project on a different station) gets over 100. If you have any word on how to fix this, please let us know!
    Thank you,
    Sunita
    Filed under: ,
  • Thu, Nov 2 2017 6:59 PM In reply to
    • dklein
    • Joined on Thu, Mar 15 2012
    • Posts 38
    • Points 535
    We are also seeing this issue, with users both on 8.9.2 and 8.9.3. We're on an ISIS 5000 and all our machines are Macs.
    EDIT: Deleting the _SearchDB_ and reindexing doesn't appear to correct the issue.
  • Thu, Nov 2 2017 10:34 PM In reply to
    • Doug Abel
    • Posts 10
    • Points 90
    I've been having this issue on both shared project/ISIS and standalone systems around NYC since Spring and it's extremely frustrating that Avid hasn't solved it. Search "current script" works but "scripts in project" doesn't. Trashing all the _SearchDB_ files doesn't fix it.
    This really limits the usefulness of the feature when in a doc project. I've resorted to searching in the finder and then manually opening that script in MC to find stuff, which is clumsy to say the least.
    Currently using 8.9.2. Not using phrasefind, just simple text search.
  • Thu, Nov 9 2017 5:22 PM In reply to
    • Doug Abel
    • Posts 10
    • Points 90
    Hi Marianna,
    Any luck on this? I know we spoke last spring and you put me in touch with support, but they weren't able to solve it.
    Doug Abel
  • Tue, Nov 14 2017 12:44 AM In reply to
    • Seibel
    • Joined on Wed, Dec 18 2013
    • Los Angeles
    • Posts 22
    • Points 230
      Avid Certified User
    We've got the same issue, on 8.9.3
  • Wed, Nov 15 2017 1:31 PM In reply to
    • Posts 8,796
    • Points 200,240
    Hello all....
    I believe this is a bug already reported and logged.... MCCET-2132....  it was recent so I am not sure it if will be fixed in the next release.....
  • Fri, Dec 8 2017 5:47 PM In reply to
    • C-King
    • Posts 29
    • Points 445
    Hi Marianna-
    I was very excited to see this fix in 8.9.4, as referenced below, but unfortunately it did not work for me. I opened each of my scripts and saved, but search still skips the same scripts as before. As an example, making a film about black plague, so every transcript includes those words, but searching on "black" only hits about half the scripts. Any tips?
    Chyld
    BBug Number: MCCET-2132. In some instan ces, the editing application did not return results when performing a search for text when “Scripts in Project” was selected as a search criteria. This has been fixed. NOTE: For this fix to work on existing scripts, you must open the script and then save it.
  • Fri, Dec 8 2017 6:21 PM In reply to
    • C-King
    • Posts 29
    • Points 445
    Got it to work-- just opening and saving the scripts was insufficient. I had to actually make a change and then save. I added pixels to the text wrap setting. So far so good! Thanks.
  • Tue, Dec 19 2017 9:21 PM In reply to
    • Doug Abel
    • Posts 10
    • Points 90
    King is Korrect. You have to make some minor change in the script to force it to save. Adding a scriptmark or changing the margin or text width will do the trick. The less-thatn-fun part is we have about 70 scripts in our project.
    I was able to manually save the most important scripts and having the global search back after 9 or so months is a godsend. Looks like the AE will have to open and slightly alter the remaining scripts ;-]
