Latest post Thu, Oct 12 2017 6:28 PM by mtahir. 2 replies.
  • Tue, Oct 10 2017 1:27 PM
    • mtahir
    • UK
    • Posts 475
    • Points 5,765
    MC and Digi 002
    I'm using MC8.9.0 with the 002 Rack. Everything works as it should except that when I exit MC, I have to power cycle the 002 in order to use it again. I get the impression that MC doesn't release it properly. After MC exits, the 1394 light stays off. Any one else with this setup seeing the same issue?
    By the way, I don't what that symbol is, in the timeline window, that shows you the 002 is connected and locked. It's unreadable. It used to be a very easty to see '002' in green when it was locked but now it looks like random pixels that you have to hover over with the mouse in order to know what they are.
    MC2018.1 (Win7) | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 64GB (32GB per CPU) 1333MHz DDR3 EEC FBDIMM | 3GB nVidia Quadro... [view my complete system specs]
    Filed under: ,
  • Thu, Oct 12 2017 8:19 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 417
    • Points 5,175
    Re: MC and Digi 002
    Has this worked correctly in the past, with previous versions of MC?
    In the past, i've used the 002 with versions 5 and 6 of MC (and win 7) and never had any problems.
    When this problem occurs, is the 002 still seen in 'devices' (in Windows System properties)?
    HP Z800,HP8600,HP8760WSonnetFusion RAID, Mediadock U320, Classic Nitris Mojo DXSymphony 5,6 & 8.5 JVC DTV1910 HD tube monitor, HP Dreamcolor, [view my complete system specs]
  • Thu, Oct 12 2017 6:28 PM In reply to
    • mtahir
    • UK
    • Posts 475
    • Points 5,765
    Re: MC and Digi 002
    Thanks for replying, Bruno.
    I've used with MC 8.x without any problems, as far as I can remember. I used it back in February but I'm not sure what version of MC I was on and I don't remember any issues. I've used it with MC5 and 6 with no issues.
    It was gone from Devices. That's one place I checked first. I had to reboot my machine to get it back. I've just tested it again and it seems to be behaving now. When I quit MC, the 48KHz led of the Sample Rate is on but the 1394 light is off. When I re-launch MC, it seems to detect it and the 1394 light comes back on. Maybe that was just one-off but I'll keep an eye on it and report back any further issues.
