Latest post Wed, Nov 29 2017 9:12 AM by Thomas Erichsen. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Oct 10 2017 8:28 AM
    • Monteur
    • Joined on Fri, Oct 14 2005
    • Switzerland
    • Posts 59
    • Points 795
    MC 8.9.2 Background Queue not working - SOLVED
    When I try to consolidate or transcode a AMA linked clip with "run in background" checked my Avid does nothing. There is no error message and everything is green. The Background Queue says "running" and "processing" but nothing happens. No progress at all.
    Is this a bug in this version? Or am I missing a setting? Previous versions worked well.
    ASUS P9X79 Deluxe Motherboard Intel Core i7 3930K Processor Nvidia Quadro 4000 32GB RAM MC 8.9.2 Avid Artist DNxIO Windows 10 [view my complete system specs]
  • Tue, Oct 10 2017 10:01 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 907
    • Points 11,610
    Re: MC 8.9.2 Background Queue not working
    I had a simmilar case with 8.9.1. It could be solved with uninstallation of MC and re-installation.
    Joachim
    Joachim Claus
  • Tue, Oct 10 2017 10:23 AM In reply to
    • Monteur
    • Switzerland
    • Posts 59
    • Points 795
    Danke für die schnelle Antwort!
    I already tried un- and re-installation. Unfortunately with no luck.
  • Tue, Oct 10 2017 2:24 PM In reply to
    • Posts 9,687
    • Points 211,425
    Christian
    I created a case so support can assist.  03306922
    Normally an unistall and reinstall resolves this so I want them to check on you.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Tue, Oct 10 2017 7:00 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,561
    • Points 59,575
    Monteur:
    Try an uninstall and then locate your Avid installation folder (C:\Program Files\Avid) and remove the Editor Transcode folder (it seems to leave behind components that may not get successfully overwritten by the new installer - I don't know why but this has worked for me more than once over the countless updates).
    Make sure you do not disturb your plugins folder...
    Then reinstall 8.9.2
    Cheers
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.7 | QT 7.7.9 | BCC 11 | Sapphire 11 | Mocha Pro 5.6 | Titler Pro 6 | Windows 10 Pro x64 | System: P6X58D... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Fri, Oct 13 2017 7:04 AM In reply to
    • Monteur
    • Switzerland
    • Posts 59
    • Points 795
    I also tried that. Still no progress. I am in contact with Avid Support now.
    Thanks for your help.
  • Fri, Oct 13 2017 10:59 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,561
    • Points 59,575
    Do you have an anti-virus program that may be interfering with the installer or perhaps the runtime service? Hope Avid support can help.
    Steve
  • Wed, Oct 18 2017 1:11 PM In reply to
    • Posts 9,687
    • Points 211,425
    Monteur....
    What was the resolution for you.....  interested in this.
  • Thu, Oct 19 2017 11:18 AM In reply to
    • Monteur
    • Switzerland
    • Posts 59
    • Points 795
    Marianna,
    Unfortunately still no progres so far. As I am in the middle of a project right now, I don't have much time to search for the cause. Apart from this the software does what it should. Maybe I reinstall Windows and everything else during the X-Mas holidays.
    Best,
    Chris
  • Thu, Oct 19 2017 2:06 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 482
    • Points 5,790
    I can report that I am seeing the same issue. Background transcode stalls, but there is no error message.
    Media Composer 8.10.0 New MacPro 6 core - 32 GB RAM old MacPros 3.33Ghz iMacs, Macbook Pros. BM, AJA, Matrox After Effects, etc [view my complete system specs]
    @jaketheeditor
  • Sat, Nov 4 2017 9:47 AM In reply to
    • Monteur
    • Switzerland
    • Posts 59
    • Points 795
    I solved the issue!
    If you own a NVIDIA Quadro 4000 don't use driver v353.82 which is recommended here:
    http://community.avid.com/forums/t/181825.aspx
    use v342.01 instead. That did the trick for me.
  • Wed, Nov 29 2017 9:12 AM In reply to
    Strangely enough, installing the driver out of the utilities folder worked for me as well....
    i7 3.4 GHz | Asus HERO Z170 | 32GB Ram | Quadro k620 | Intensity Pro 4K | WIN7 64bit Pro [view my complete system specs]
