Latest post Thu, Oct 12 2017 8:28 PM by Marianna. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Oct 7 2017 2:28 AM
    Incorrect Audio Track Allocations in MC 8.9.2
    I have both a 6 Track DHxHD 175x and H.264 of the same Video File with the following Track Allocations.
    L, C, R, LS, RS, LFE
    If I AMA Link either one in V8.8.5 and open them in the Source Window the Audio Track Allocations are all correct but if I AMA Link them in V8.9.2 I get the following.
    C, L, R, LFE, LS, RS
    Kind of weird and totally wrong.
    Any suggestions or is this just a new Bug.
    Mac Pro - 5,1 - 2 x 3.46ghz 6 Core Xeons Sierra 10.12.6 64gb of OWC RAM GTX-980Ti Video Card Avid Nitris DX Symphony 2018.5 [view my complete system specs]
  • Sun, Oct 8 2017 9:03 PM In reply to
    Re: Incorrect Audio Track Allocations in MC 8.9.2
    Bump.
    Anyone from Avid have any suggestions.
    This is making 8.9.x absolutely useless.
  • Mon, Oct 9 2017 3:04 PM In reply to
    • Posts 10,284
    • Points 219,185
    Brent
    Let me check on this with support.  I created a case 03306303 so lets see if it can be reproduced.
    Do you mind doing me a favor...... can you update your spec's please so we know the correct ones to test against?
  • Mon, Oct 9 2017 7:03 PM In reply to
    Here's what my Link settings and the timeline view look like. As you can see the Centre is on track one for some reason and the LFE is on track four. Nothing in the project has changed, including settings since upgrading from 8.8.5 to 8.9.2
    The DNxHD Master file has 6 discreet mono tracks and the H.264 is setup with a 5.1 - L, C, R, LS, RS, LFE track allocation.
    Not sure why but I can only attach one screen shot so I will put the second one in the next post.
  • Mon, Oct 9 2017 7:04 PM In reply to
    Second screen shot.
  • Mon, Oct 9 2017 10:40 PM In reply to
    Just as an update.
    I have checked these files in MC 8.4.5, ,8.7.2, 8.8.5, Adobe Premiere, FCP-7, FCP-X and DaVinci Resolve. The only one that displays the Track Allocations improperly is MC 8.9.2. I haven't bothered going back to 8.9.0 or 8.9.1 but I suspect I would get the same results as 8.9.2.
  • Tue, Oct 10 2017 8:25 AM In reply to
    Just tried this in 8.9.1 but there the track allocation is correct in my test. If you could upload a small test clip, I could check with that. J
  • Thu, Oct 12 2017 5:38 PM In reply to
    I've just installed 8.9.2 on my second MBP and here's what I have found.
    I AMA Linked the clip in a project in 8.8.5 first which shows the allocations properly. I then upgraded to 8.9.2 and after a restart I opened MC 8.9.2. The Track Allocations are now correct but if I delete the Master Clip and AMA Link it again the Track Allocations are now wrong.
    This is a really weird bug.
  • Thu, Oct 12 2017 8:28 PM In reply to
    • Posts 10,284
    • Points 219,185
    Brent
    I just updated Gilbrad on this and added this information to the case.  Offered to assist him if need be...
