Latest post Mon, Oct 9 2017 12:23 PM by Mercer. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Oct 2 2017 4:14 PM
    Sys Error status 5 Access denied
    I am getting the following error trying to open projects on MC 8.8.2 in the "shared avid projects" folder
    Error message
    DISK_ACCESS_DENIED
    SYS_ERROR, status 5, Access is denied
    Anyone have any idea what the issue is?
  • Mon, Oct 2 2017 4:25 PM In reply to
    • Posts 9,250
    • Points 206,010
    Re: Sys Error status 5 Access denied
    Scottyboy.......
    Fix:  Depending on the platform you have you will need to remove the following folder:
    Note: This applies for both Application Manager and Avid License Control utilities in all versions 6.x - 8.x.
                       PC -  Look for the following folders.  If found, delete the entire folder.
                                 C:\ProgramData\Avid\Licenses
                       Mac - Look for the following folders. If found, delete the entire folder.
                                 Macintosh HD/Library/Application_Support/Avid/Licenses
    Important:   If you can’t find the specific folder in Windows, go to Folder Options in the Tools menu and select “Show Hidden Folders.”
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Tue, Oct 3 2017 1:45 PM In reply to
    That didnt really help, after deleting the folder I had to reactivate but some project still won't load, same error as above, some of them work, some give the error
    I have no idea how to fix it
  • Tue, Oct 3 2017 6:44 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,533
    • Points 59,265
    Where is the 'shared projects folder' and is there something about that drive that could explain limited access rights?
    Camera(s) PXW-X70, HDR-FX1, Hero 3+ | MC 18.5 | QT 7.7.9 | BCC 11 | Sapphire 11 | Mocha Pro 5.6 | Titler Pro 6 | Windows 10 Pro x64 | System: P6X58D-E... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Tue, Oct 3 2017 7:16 PM In reply to
    • Posts 9,250
    • Points 206,010
    where are the projects located? on the same drives or different ones?
  • Mon, Oct 9 2017 9:40 AM In reply to
    Hi.
    They are located in the users default "shared projects" folder, they havent been moved and the permissions all look fine with full access.. its very odd
  • Mon, Oct 9 2017 12:23 PM In reply to
    • Mercer
    • Joined on Thu, Apr 15 2010
    • Posts 372
    • Points 4,705
    Try adding 'Everyone', if it's not already there and giving full access to that. Security shouldn't be an issue as it's one folder and in your public user.
