Latest post Wed, Sep 27 2017 10:19 AM by Bruno M. 4 replies.
  • Wed, Sep 27 2017 1:33 AM
    • mmagder
    • Joined on Wed, Sep 1 2010
    • Passaic NJ
    • Posts 198
    • Points 2,515
    can you use previous edit button without dual roller mode
    Hi, can you use the previous A or next S buttons without it going into dual roller mode.
    thanks
    Mac OSX 10.14.1 3.8 GHz Intel Core i5 MC 20180.10 [view my complete system specs]
  • Wed, Sep 27 2017 1:45 AM In reply to
    Re: can you use previous edit button without dual roller mode
    In a word No. Try remapping the Rewind and Fast Forward buttons (also strangely named) from the Command Palette to the A and S keys to do what you want.
  • Wed, Sep 27 2017 2:14 AM In reply to
    • mmagder
    • Passaic NJ
    • Posts 198
    • Points 2,515
    doesn't seem to work, there was as douglass tutorial from yrs ago, can't get it to play though.
    thanks
  • Wed, Sep 27 2017 3:36 AM In reply to
    • mmagder
    • Passaic NJ
    • Posts 198
    • Points 2,515
    THIS WORKS Re: can you use previous edit button without dual roller mode
    this works, found this tutorial, map keys, then go to Composer setting in settings. Select ignore track selectors.
    https://www.youtube.com/watch?v=wBGC5kDhzNs&pbjreload=10
    thanks
  • Wed, Sep 27 2017 10:19 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 551
    • Points 7,035
    Re: THIS WORKS Re: can you use previous edit button without dual roller mode
    Rather than use the 'Ignore Track Selectors' option in the Composer settings, You can use the ALT/option key in conjunction with the fast forward/rewind buttons to temporarily ignore the track selections. Gives you the best of both worlds without having keep going to the settings menus.
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
