Latest post Thu, Sep 28 2017 11:06 AM by BarkinMadd. 7 replies.
  • Tue, Sep 26 2017 11:09 AM
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,546
    • Points 59,430
    Is BMD's intensity pro 4K a decent solution for HDMI out to a hero display from MC?
    Looking for a low cost solution and wondered if folks here are using this card with MC 8.9.x (and Resolve 14). Any thoughts are appreciated. Thanks.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.7 | QT 7.7.9 | BCC 11 | Sapphire 11 | Mocha Pro 5.6 | Titler Pro 6 | Windows 10 Pro x64 | System: P6X58D... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Tue, Sep 26 2017 4:51 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,364
    • Points 43,435
    Re: Is BMD's intensity pro 4K a decent solution for HDMI out to a hero display from MC?
    I have the BMD Intensity Pro 4K. It's connect via HDMI to a 4K UHD TV for monitoring. and my older SD equipment for input (Laserdisc, pro VHS, etc.) It works well with both MC and of course with Resolve. About the only issue I have is that the sound from MC always routes to the TV if I have the hardware enabled, even if the TV is turned off. I've never found a way to worjk around that one.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
  • Tue, Sep 26 2017 5:30 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,546
    • Points 59,430
    Thanks Dave - much appreciated.
    Too bad there isn't a way to tell MC to ignore the Intensity Pro 4K hardware and use the internal (Windows) mixer, instead. Maybe raise this as a defect (or at least a feature request).
    Cheers
    Steve
  • Tue, Sep 26 2017 6:26 PM In reply to
    • Posts 9,323
    • Points 206,845
    Barkin
    I know this was suggested before and Randy in the deisng group said it wasnt that easy - but I fail to remember why.  Old age
    I will check again....
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Tue, Sep 26 2017 9:24 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,546
    • Points 59,430
    Marianna... if you are old then I am ancient - lol
    To make matters worse - I may have been the one who suggested it before... memory is not as good as it used to be...
    Cheers
    Steve
  • Tue, Sep 26 2017 9:43 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,364
    • Points 43,435
    Marianna, you are not getting old. You're like a bottle of Chateau Cheval Blanc; you just get better over time.
    Dave S.
  • Thu, Sep 28 2017 2:05 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 137
    • Points 1,410
    I use a small USB powered hdmi audio splitter, hdmi in rca audio out and hdmi out. I wish there was an option to go audio out from avid though, I would imagine there would be audio sync issues though.
    iMac Retina27 late 2017 4.5Gz i7 40GB AMD 8GB with Sata Raid OS 10.13.3 MC 2018.3 BMD mini monitor with Eizo monitor [view my complete system specs]
  • Thu, Sep 28 2017 11:06 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,546
    • Points 59,430
    Martin Fox:
    ... I would imagine there would be audio sync issues though.
    Good point. Perhaps that's at the root of the issue.
    Steve
