Latest post Sat, Sep 23 2017 7:01 AM by AndrewAction. 1 replies.
Page 1 of 1 (2 items)
  • Sat, Sep 23 2017 5:01 AM
    Trouble with MCF due to my AAX Plugins
    Hi everyone,
    I'm new to MC so I've downloaded MC First and want to share my initial experience.  I had lots of trouble lauching the program.  Since I own PTHD 12.8 and have lots of AAX plugins, MCF gave me tons of trouble because of several AAX plugins in my folder which are made by some farily popular developers like Slate Digital, Line6, and Positive Grid. (A more comprehensive list is below)  I couldn't launch MFC without it crashing unless I removed plugins from my plugin folder.  I have close to 500- so it took some time to narrow it down and realize what happened, but I just put all plugins in the Unused folder and launched again.  Not convenient at all for me to have to do that every time I launch a different Avid program, but...
    Anyway- it launches now and I load my video and immediately learn that I can only use 7 avid plugins.  I re-read the website and it says I can use plugins from the Avid Marketplace, but even when BF76, Channel Strip, Smack, Sci-Fi, Sansamp all are in my plugin folder, they don't appear in MFC.
    After spending some time testing, I narrowed the crashes down to a list of plugins that I could keep in my folder without causing MFC to crash.  Below are images of the error messages and a list showing which plugins gave MCF trouble.  I also have a crash report, but it won't let me upload it here.  I'm worried that even if I buy Media Composer that my plugins will continue to cause problems and be annoying to work with.  Any solutions/suggestions are appreciated.
    EDIT:  FYI, you can drag these images to your desktop to view them- this website is cutting them off.
    DAW-
    Win7 64 bit
    Intel i7 965 3.2 ghz
    12 gigs of RAM
    SATA and SSD drives
    Lynx AES 16e interface
    Compatible with MCF:
    A1TriggerGate.aaxplugin
    AIRChorus.aaxplugin
    AIRDistortion.aaxplugin
    AIRDynamicDelay.aaxplugin
    AIREnhancer.aaxplugin
    AIREnsemble.aaxplugin
    AIRFilterGate.aaxplugin
    AIRFlanger.aaxplugin
    AIRFrequencyShifter.aaxplugin
    AIRFuzz-Wah.aaxplugin
    AIRKillEQ.aaxplugin
    AIRLo-Fi.aaxplugin
    AIRMulti-Chorus.aaxplugin
    AIRMulti-Delay.aaxplugin
    AIRNon-LinearReverb.aaxplugin
    AIRPhaser.aaxplugin
    AIRReverb.aaxplugin
    AIRSpringReverb.aaxplugin
    AIRStereoWidth.aaxplugin
    AIRTalkbox.aaxplugin
    AIRVintageFilter.aaxplugin
    Antares Audio Technologies
    AutoPan.aaxplugin
    BarkOfDog.aaxplugin
    BC PatchWork AAX.aaxplugin
    BC PatchWork Synth AAX.aaxplugin
    BF-76.aaxplugin
    Boom.aaxplugin
    bx_cleansweep V2.aaxplugin
    bx_opto Pedal.aaxplugin
    bx_solo.aaxplugin
    bx_subfilter.aaxplugin
    bx_tuner.aaxplugin
    chipsounds.aaxplugin
    ClickII.aaxplugin
    DB-33.aaxplugin
    dirlist.txt
    Dither.aaxplugin
    DownMixer.aaxplugin
    DrMS_AAX.aaxplugin
    DVerb.aaxplugin
    DynamicsIII.aaxplugin
    Eleven Lite.aaxplugin
    EQIII.aaxplugin
    FabFilter Pro-G.aaxplugin
    FabFilter Pro-MB.aaxplugin
    FabFilter Pro-Q 2.aaxplugin
    FabFilter Saturn.aaxplugin
    GateyWatey.aaxplugin
    Hybrid.aaxplugin
    InTune.aaxplugin
    Invert-Duplicate.aaxplugin
    iZDDLYAAXHook.aaxplugin
    iZNeutrinoAAXHook.aaxplugin
    iZOzone5AAXHook.aaxplugin
    iZRX6DeclickerAAXHook.aaxplugin
    iZRX6DeclipperAAXHook.aaxplugin
    iZRX6HumRemovalAAXHook.aaxplugin
    iZRX6VoiceDenoiserAAXHook.aaxplugin
    iZVinylAAXHook.aaxplugin
    LoFi.aaxplugin
    MasterMeter.aaxplugin
    Maxim.aaxplugin
    MiniGrand.aaxplugin
    ModDelay_III.aaxplugin
    Normalize-Gain.aaxplugin
    Panipulator.aaxplugin
    Pitch Shift Legacy.aaxplugin
    PitchII.aaxplugin
    Plus10db.aaxplugin
    RectiFi.aaxplugin
    Reverse-DC Removal.aaxplugin
    SansAmp PSA-1.aaxplugin
    SciFi.aaxplugin
    SignalGenerator.aaxplugin
    Soundtoys
    Space.aaxplugin
    Speaker.aaxplugin
    StereoDelta.aaxplugin
    Structure.aaxplugin
    Time Shift.aaxplugin
    TimeAdjuster.aaxplugin
    Trim.aaxplugin
    Vacuum.aaxplugin
    ValhallaFreqEcho.aaxplugin
    ValhallaPlate.aaxplugin
    ValhallaRoom.aaxplugin
    ValhallaSpaceModulator.aaxplugin
    ValhallaVintageVerb.aaxplugin
    VariFi.aaxplugin
    WaveShell-AAX 9.91.aaxplugin
    WaveShell2-AAX 9.91.aaxplugin
    WidthKnob.aaxplugin
    XPand!2.aaxplugin
    Some of these are causing problems- can't haven't completely narrowed it down yet:
    Absynth 5.aaxplugin
    Battery 4.aaxplugin
    BIAS AMP.aaxplugin
    BIAS FX.aaxplugin
    BIAS Pedal.aaxplugin
    BOD.aaxplugin
    ChannelStrip.aaxplugin
    DC1A2.aaxplugin
    DeBleeder.aaxplugin
    DeBleeder_Mono.aaxplugin
    DeBleeder_Stereo.aaxplugin
    DF-CLARIFY.aaxplugin
    DF-TRANS.aaxplugin
    dirlist.txt
    Driver.aaxplugin
    DrMS.aaxplugin
    elysia niveau filter.aaxplugin
    Eventide
    Filterjam.aaxplugin
    Finality Advanced.aaxplugin
    Finality Lite.aaxplugin
    FM8.aaxplugin
    GainReduction.aaxplugin
    Guitar Rig 5.aaxplugin
    HoRNetHarmonics.aaxplugin
    IVGI.aaxplugin
    Joey Sturgis Tones
    JSTClip.aaxplugin
    KClip - Surround.aaxplugin
    KClip.aaxplugin
    Komplete Kontrol.aaxplugin
    Kontakt 5.aaxplugin
    Line 6
    Magic AB V2.aaxplugin
    Massive.aaxplugin
    Megaphone.aaxplugin
    MeldaProduction
    mixIR2.aaxplugin
    MJUC.aaxplugin
    Muteomatic.aaxplugin
    NUGEN ISL2.aaxplugin
    OuterSpace.aaxplugin
    PG Digital EQ.aaxplugin
    PG FET Compressor.aaxplugin
    PG Optical Compressor.aaxplugin
    PG Passive EQ.aaxplugin
    PG Tube Compressor.aaxplugin
    PG Tube EQ.aaxplugin
    Pink.aaxplugin
    Pixelator.aaxplugin
    Play.aaxplugin
    Reaktor 6.aaxplugin
    Replika.aaxplugin
    RIN-M.aaxplugin
    SideWidener.aaxplugin
    Slate Digital
    Slate Digital FG-X.aaxplugin
    Solid Bus Comp.aaxplugin
    Solid Dynamics.aaxplugin
    Solid EQ.aaxplugin
    SPL Attacker.aaxplugin
    SPL De-Verb.aaxplugin
    SPL Free Ranger.aaxplugin
    SPL Mo-Verb.aaxplugin
    SPL Transient Designer Plus.aaxplugin
    SPL Transient Designer.aaxplugin
    SSDSampler.aaxplugin
    StandardCLIP.aaxplugin
    SubDestroyer.aaxplugin
    Supercharger.aaxplugin
    TH3.aaxplugin
    Thermionik Serpent.aaxplugin
    Toneforge - Ben Bruce.aaxplugin
    Toneforge - Menace.aaxplugin
    Transient Master.aaxplugin
    Transify.aaxplugin
    Trigger_2.aaxplugin
    Unfiltered Audio Indent.aaxplugin
    VocALignPro.aaxplugin
    xcite.aaxplugin
  • Sat, Sep 23 2017 7:01 AM In reply to
    Re: Trouble with MCF due to my AAX Plugins
    For the mac2Qt error you may find the solution in this old thread  ( http://community.avid.com/forums/p/106902/681732.aspx )
    To test whether the issues remain with the full version of MC you can download and install a 30 day demo version. You need to uninstall MC | First before installing MC.  And then uninstall MC demo before going back to MC | First
    I do not know a way to get around the audio Plug-ins issue with MC I First other than removing the plugins from the folder.  (that is not saying that there may not be one!!)
    If in your situation I would find a time I did not need to use PT's for a few days and use that time to get to grips with how MC | First works. Then having this basic experience of MC workings, uninstall MC | First and install the MC demo with your audio plug-ins back in their folder.   Should quickly enable you to find how many of them work.
    FWIW there is a deal that you can get an annual subscription for all of the Pro Tools HD plug-ins.  In theory (I have not tested it) they should all work with MC (and MC | First).
