Latest post Mon, Oct 2 2017 10:19 AM by Joachim Claus. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Sep 21 2017 8:42 AM
    • kd-53
    • Joined on Wed, Apr 28 2010
    • Duesseldorf, Germany
    • Posts 23
    • Points 310
    Problem with audio punch-in tool
    Hi All
    The Audio Punch-In tool doesn't work any longer for me as it did for years.
    Scenario:Mark-in point is set. Input source: windows mixer. When I want to start a voice over, MC make only "Pling". No error message, nothing. The same is true if I hit the Play In/Out Button.
    I can enter in the Punch-In tool whatever I want: New channel, existig channel, different target bins, with or without mark out point, with or without pre/post/handles.
    Where is my mistake? I have no idea where to search. Probably it is something within the settings, as the system is setup new.
    My system: New built computer with i7-7700K, new Win 10 Prof, fresh installed MC 8.9 one month ago.
    The Microphone is connected via audio-input on the mainboard. With the connected loudspeaker I can hear that it is working.
    Project: 1080i/50
    Thank you for your help!
    Mobo: Asus Z270-A, i7-7700K, 32GB Ram, Win 10 Prof 64, GeForce GTX 1060 with 6 GB Ram, BM Intensity Pro 4K, MC 2018.8, BCC11, 2 x 24" monitors, Sony... [view my complete system specs]
  • Mon, Sep 25 2017 7:41 AM In reply to
    • kd-53
    • Posts 23
    • Points 310
    Re: Problem with audio punch-in tool
    Hi all,
    more than 150 views and nobody has an idea? Please give me a hint where to search. Probably it is a silly thing.
    Thank you!
    Klaus-Dieter
  • Mon, Sep 25 2017 3:03 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 917
    • Points 11,740
    Uninstall MC and Re-Install it. May be it will help.
    Joachim
    Joachim Claus
  • Tue, Sep 26 2017 10:26 AM In reply to
    • kd-53
    • Posts 23
    • Points 310
    Thank you! The problem is solved.
    Uninstalling 8.9 and installing 8.9.1 solved the problem, but why?
    Klaus-Dieter
  • Tue, Sep 26 2017 5:36 PM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 1,484
    • Points 17,545
    Maybe the issue has been fixed in 8.9.1!
    Media Composer 2018.5 (Symphony Option), ASUS P8P67 Deluxe, Intel i7 2600k, 16G DDR3-1600, PNY NVIDIA Quadro 2000 (353.82), Windows 10 Pro. Boris Red 5... [view my complete system specs]
    Sylvain Primeau
    Self-employed worker - Les productions Primeau Medias
    primeaumedias.com
    Radio-Canada/CBC news editor
    cbc.ca / ici.radio-canada.ca
  • Mon, Oct 2 2017 10:19 AM In reply to
    • Joachim Claus
    • Posts 917
    • Points 11,740
    kd-53:
    This can happen if you update MC without uninstalling it. Some dll's may not be correctly replaced. The safe way is uninstall the old version and install the new version.
    Joachim
    Joachim Claus
