Latest post Fri, Sep 22 2017 4:50 PM by Pilot. 3 replies.
  • Wed, Sep 20 2017 11:13 PM
    • mile81
    • Joined on Sat, Jul 19 2014
    • Posts 15
    • Points 185
    How to use the same clip
    Hello,
    I have a short clip that I want extended. So what I've done is added the same clip right after. The problem is that you can tell that the clip starts all over again, rather than looking like its just looping continuously from the beginning.
    Any help woul dbe appreciated.
    MacBook Pro (Early 2008 model) 2.4GHz Intel Core 2 Duo, Memory 2GB 667 MHz DDR2 SDRAM [view my complete system specs]
  • Thu, Sep 21 2017 4:48 PM In reply to
    Re: How to use the same clip
    I'm not quite sure what you are trying to achieve?
    If you add the same clip again of course it will stat again. Its the same clip it must.
    You could slow the original clip down to make it play longer.
    You could freeze the last frame and use the freeze to extend it.
    You could reverse the second copy of the clip so the extended part plays backwards.
    Really depends on whats in the shot and how much it moves.
  • Thu, Sep 21 2017 8:14 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,545
    • Points 45,590
    Are y9ou trying to make a sequence that you can extend infintely by splicing back to front?
    Dave S.
  • Fri, Sep 22 2017 4:50 PM In reply to
    • Pilot
    • Tel Aviv
    • Posts 63
    • Points 735
    Hello mile81,
    from your specs:
    You run Media Composer | First on this computer ?
    Geeked
    For MC|First:Win 7 Ultimate x64 SP1 / ASUS K54C/CPU B960 @ 2.20GHz/DDR3 8GB RAM/ Intel HD Graphics 2GB *For MC 8.4.4/Symphony option/Win 7 Ultimate x64... [view my complete system specs]
