Latest post Wed, Sep 13 2017 10:54 PM by Marianna. 1 replies.
Page 1 of 1 (2 items)
  • Wed, Sep 13 2017 12:15 PM
    • ugo1
    • Joined on Thu, Jul 13 2006
    • Italy
    • Posts 260
    • Points 3,610
    Exception error
    i'm in the ending of a project and I start getting this error
    Ugo
    Memory stats: physical = 32435 MB, virtual = 134217727 MB, restriction = 0 MB
    WARNING: Requested LocateBuffer size 2048MB is the same as current size 2048MB.
    Set persistent image cache limit: 200.0 MB in C:/Users/Public/Documents/Avid Media Composer/AvidImageCache
    AWin32Mixer::Open inputMixerID = 13
    DirectSound ADM running on Windows OS Version Major=6 Minor=2 Build=9200
    Created ADM Device : 1394 Audio
    AlertableTimer Win32 constructor, default system clock resolution min = 1, max = 1000000
    MCBootstrap::gwhoami = 30
    AVX Library V1.5
    OpenGL implementation found:
    vendor = Brian Paul
    renderer = Mesa OffScreen16
    version = 1.5 Mesa 6.4
    This OpenGL implementation does not support hardware texture render
    dimensioni massime di rendering: = Canale 1920 x 1080 a 8 bit per pixel
    vendor = NVIDIA Corporation
    renderer = GeForce GTX 1080/PCIe/SSE2
    version = 4.5.0 NVIDIA 382.53
    This OpenGL implementation supports hardware texture render
    AME CPU Buffer Deallocator Registered Successfully
    AME GPU Buffer Deallocator Registered Successfully
    Copie MonCon: GPU, CPU
    Tipo di trasferimento ACPL: OGL
    Modalità di trasferimento ACPL: NonOverlapped
    ACPL GPU VRAM Capacity: 8192MB
    Newer CPU<->GPU bus speeds detected (3.4959)
    AAF DLL loaded from : C:\Bin\Multimedia\Media Composer\AAFCOAPI.dll
    AAF DLL version : 1.1.6 (9195) [0]
    Avid Media Access: Device monitor successfully initialized
    DFM loaded. 76 entries initialized. Scripts directory 'C:\Bin\Multimedia\Media Composer\SupportingFiles\CodecToolkit_Config\'
    Failed to setup chained feature toggle from /AvidMediaEngine/QuickTimeMediaContainer/TruncateFractionalStarOffsetsToFullFramePrecharge to /QuickTimeMediaContainer/TruncateFractionalStarOffsetsToFullFramePrecharge. Second toggle is not registered.MSM directories:1
    LocalMDB::LoadMobsFromMDB() inCallback=0000000000000000 sourceOnle=FALSE
    mediaDirPath phyMobs logMobs
    "C:\Users\Public\Documents\Avid Media Composer\Avid_MediaFiles\" 0.00 sec
    total time=0.00 mobs=0
    Media Drives:
    OPERATION SYSTEM (C:), OSVolID = 67, 243617788 totalKB, 154341836 freeKB, 154040388 realFreeKB
    REELS (D:), OSVolID = 68, 976629756 totalKB, 591711968 freeKB, 590556281 realFreeKB
    RENDERING (E:), OSVolID = 69, 244197372 totalKB, 223928792 freeKB, 223491432 realFreeKB
    EXPORT E MAPS (F:), OSVolID = 70, 244197372 totalKB, 216987524 freeKB, 216563721 realFreeKB
    GAMES (G:), OSVolID = 71, 488385532 totalKB, 488163464 freeKB, 487210020 realFreeKB
    OTHER (I:), OSVolID = 73, 976760828 totalKB, 778156708 freeKB, 776636871 realFreeKB
    COM2: error (2) Impossibile trovare il file specificato.
    MAX_INDEXES_TO_READ set to 10240
    MXF Indexes in Memory changed to 524288000: Old Size 524288000
    In Init ARO Cmds
    MTSC state = 0The single frame player will be built for a length of 3600 frames
    MSMRescan() took: 0.058000s
    The default render wait time is 50
    EWC Play is supported...
    PreReads will bias DueTime by 0.000000 seconds.
    PlayLoopThread::CheckForExceptions: Exception: StreamingPlayConsumer::ExecutePass TIMEOUT
    Exception caught in APlayer::Play - Exception: StreamingPlayConsumer::ExecutePass TIMEOUT
    Exception:
    @ Wed Sep 13 14:04:16 2017
    8.9.1.46710
    * Exception: StreamingPlayConsumer::ExecutePass TIMEOUT
    Case: Phantek Enthoo Luxe, Motherboard: Asus Prime X299 deluxe, Cpu: Core i9-7900K,Ram: 32GB Ripjaws 4, GPU: Asus Nvidia 1080, Sound card: X-Fi Forte... [view my complete system specs]
  • Wed, Sep 13 2017 10:54 PM In reply to
    • Posts 8,499
    • Points 111,015
    Re: Exception error
    Ugo1
    Make sure all cards and cables to any attached devices like I/O etc. are seated firmly.  Check your Graphics card too.
    Also, this has been known to occur if your deck is playing back and outputting an HD format that does not match your project type format.  Example:  The deck is playing back and outputting 720p, but you project is 1080i.
    Note: It is now possible to mix framrates in Media Composer version 4.x and higher of the software. Even though it is possible to mix framerates in the timeline, the deck's output must match the project's format when capturing.
    AOL IM:  avidmarianna
    Skype: mariannamontague
