Latest post Mon, Sep 18 2017 5:47 AM by dew. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Sep 13 2017 5:45 AM
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 487
    • Points 6,195
    removing hiss
    Hey I have some audio where there is some hiss noise. I was wondering if there where any native effects in avid that would be good to help out on that or if its only with a 3rd party plugin I can do this with?
  • Wed, Sep 13 2017 6:05 AM In reply to
    Re: removing hiss
    Find the frequency of the hiss with a multiband EQ plug in.  Suggested method would be to maximize the gain on one of the bands with a very narrow "Q" (very tall thin curve.) move that band slowly through the frequency till you can locate the value where the hiss is loudest.  Then pull the bands gain value down into the negative to reduce the hiss. Widen the curve to find the sweet spot between hiss reduction and distorting your audio.    (I find accurately locating the hiss by making it louder much easier than trying to hear the hiss reducing.)
    (EQ3 7-Band works well. Has a nice frequency graph, good Q values. Select Preview to hear results)
  • Wed, Sep 13 2017 10:21 AM In reply to
    Re: removing hiss
    As Andrew says. The other approach is to use EQ to boost the frequencies you want to hear (and thereby improving the seperation)
    You can use nosie reduction but its difficult to get it to sound good (it can tend to pump in and out)
    Utlimatley it depends on how the hiss is made up. If its white nosier and represents a spread of random frequencies then you are fighting a losing battle.
    ACI Moderator. I'm not employed by Avid or work for them. I just do this in my spare time. Symphony V8.6 / 8.3.1 HP Z400 system [view my complete system specs]
  • Wed, Sep 13 2017 3:53 PM In reply to
    • mtahir
    • UK
    • Posts 475
    • Points 5,765
    Re: removing hiss
    I've done what Andrew has suggested before just to take a bit off the sibilance rather than remove hiss. But Pat is right in that it depends on what type of noise is it. I've dealt with white noise over that all important first 4KHz when dealing with dialogue using Audition - it's ok as long as you don't go overboard. It can take it down for you a but as Pat says it's a battle and a compromise at best.
    If you are going to use Audition (has various noise removing functions) then make sure you select the check box that allows you to listen to noise being removed (one function has that in Audition v3 - not sure how the later versions work).  This is where you will hear how much of your audio is being removed. Then it's a case picking a compromise that you're happy with.
    There is iZotope RX 6 but I only tried previous versions in demo mode. Might be worth a look.
    MC2018.1 (Win7) | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 64GB (32GB per CPU) 1333MHz DDR3 EEC FBDIMM | 3GB nVidia Quadro... [view my complete system specs]
  • Thu, Sep 14 2017 5:39 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,298
    • Points 42,645
    Re: removing hiss
    I use Sony (now Magix) Spectralayers for doing things like this. It's possble to get a surprisingly clean dialogue out of white noise. However, I am not going to recommend Spectralayers as it has a rather high learning curve. Izotope RX 6 is easier to use (and if I had to replace Spectralayers today, I'd go with Izotope). Note that even in their lowest end product, there is a tool for pulling dialogue out of noisy backgrounds like AC. I'm pretty sure they have a demo mode. It's pretty inexpensive and you may get better results than playing with the EQ, especially if the hiss is wide band.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC 8.x (generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
  • Thu, Sep 14 2017 6:53 AM In reply to
    • zonik
    • Joined on Sat, Jan 15 2011
    • Posts 26
    • Points 425
    Re: removing hiss
    I recommend the third party plugin iZotope RX6 Standard. If you get from time to time noiseful audio it's the tool you want. There's a voice denoise plugin in the bundle able to auto adapt to the noise.
    Media Composer 8.8 Windows 10 Pro [view my complete system specs]
  • Thu, Sep 14 2017 3:48 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 417
    • Points 5,175
    Re: removing hiss
    I've played with Izotope RX5 (standalone) and I found it most effective when I used it's 'learn' mode, although there was a certain amount of 'pumping' with the settings the software defaults to. It then becomes a compromise as to how much to dial back the effect without re-introducing too much noise.
    I did once sit in with an audio guy who had around 10 seconds of clean atmos of a dialogue clip he was tring to improve. By analysing the spectrum of the clean clip, he was able to do a pretty good job of cleaning up the noise. I can't remember what plugin he was using, but I suspect this is the best way of removing any wide-band noise.
    HP Z800,HP8600,HP8760WSonnetFusion RAID, Mediadock U320, Classic Nitris Mojo DXSymphony 5,6 & 8.5 JVC DTV1910 HD tube monitor, HP Dreamcolor, [view my complete system specs]
  • Fri, Sep 15 2017 2:11 PM In reply to
    Re: removing hiss
    MC's own Audio EQ tool has a tape hiss filter that's always been sufficient for my needs.
    MC 6.0.4,Gateway FX6800, i7 920 Processor, Windows 10 Pro (upgraded from Win 7 Pro 64 SP1), 6gb Ram, GeForce GT 710 (2gb), 2 JVC HM170U Camcorders, 1 Canon... [view my complete system specs]
  • Mon, Sep 18 2017 5:47 AM In reply to
    • dew
    • Posts 487
    • Points 6,195
    Re: removing hiss
    thanks for the replies. Right now buying any plugins is out. I will look at some of the other options provided. Thanks again
