Latest post Wed, Sep 13 2017 9:48 AM by Roger Shufflebottom. 2 replies.
  • Mon, Sep 11 2017 12:17 AM
    Error upon export: errcode: 4294965262
    Hello all,
    I was wondering if anyone has a thought on a strange error I'm getting when trying to export an H264 10kbps Quicktime in a 1920x1080 23.976p project in Avid MC 6.5.4.2.  The message is:
    "Exception: Movie export from procedures FAILED!, errcode:  4294965262"
    I tried divide and conquer to rule out corrupt media, and both halves of the sequence, in separate timelines, exported under the same export parameters with no problem whatsoever.  The timeline is about 86 minutes long.  The error on the full timeline export came at about 80% in, (at 01:52:32 of 02:19:10).
    I saw in another post that the presence of AMA clips caused it for them, so I weeded out the few AMA clips in the sequence.  There are now none, and I re-did the full export of the timeline and the same error message appeared.  I can't report if it happened at the same position in the export.  It may or may not have.  All media in the timeline should be a flavor of DNX, at 23.98fps.
    All effects, video and audio, had been rendered.
    Disk Utility repair had been run on the media drives before the 2nd failed export.
    I can successfully run a video mixdown to Dnx36 on the entire sequence.
    So I'm a little puzzled at the moment.  Since each half can export fine, is there some kind of hardware limit I'm reaching?  I have been exporting even longer 89 minute sequences for months on the same machine.
    The machine is a Mid 2010 Mac Pro tower:
    2 x 2.66 Ghz 6-core
    32GB 1333 DDR3 ECC RAM
    ATI Radeon HD 5770 1024 MB GPU
    OS X 10.8.5
    The media reside on 3 x 4TB GTech external drives connecting via FireWire800 (one is connected via USB 2), but this has been the case for a year with no problems.
    Any thoughts that anyone might have would be greatly appreciated.  Thank you in advance!
    Bret
  • Wed, Sep 13 2017 9:41 AM In reply to
    Re: Error upon export: errcode: 4294965262
    10 kbps? Really? How are you setting that (and it is very low)? Also, that error looks rather like lack of space on the destination drive.
    iMac i5 27", 24GB RAM, OS 10.11.6 with Symphony 8.10., BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.12.5 with MC 8.10 and BMD Ultrastudio... [view my complete system specs]
  • Wed, Sep 13 2017 9:48 AM In reply to
    OK  I see where you set that but it is still very low. Works here on later system.
