Latest post Tue, Oct 3 2017 12:13 AM by George Angeludis. 37 replies.
Page 2 of 3 (38 items) < Previous 1 2 3 Next >
  • Tue, Sep 5 2017 8:01 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,395
    • Points 15,355
    Re: GH5 4K files will NOT transcode. Constant Errors.
    Atomike:
    The file will transcode without crashing, but since I only get a green screen, that seems like a hollow victory.
    It looks more like a 10-bit codec. I did not have any problems with "mov" 4k 50p 8bit 4: 2: 0 of GH5.
    What says "MediaInfo"?
    V.
    AVID MC8.10 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 385.08, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.9.9, W10 - 64bit Professional... [view my complete system specs]
  • Tue, Sep 5 2017 8:24 PM In reply to
    • Atomike
    • Nebraska
    • Posts 700
    • Points 10,605
    For video, it says AVC Long-GOP High422.  So, it looks like despite my thoughts to record at 4:2:0, it looks like it's 4:2:2, and you are 100% correct.  Many thanks for everyone's suggestions, but my own incompetence seems to be the common denominator in all of these issues.
    I will do a 4:2:0 test, but I'm guessing that will ingest fine.  As a relatively new format, I can't be upset with Avid for not supporting 4:2:2, and so all of my scathing and hyperbolic criticisms are withdrawn.  I sure enjoyed being mad though. Now, I have nothing left to do but figure out how to best deal with my 4:2:2 mistake.
    I think I read in the other thread that people were having luck using Resolve or Fusion or something similar to convert 4:2:2, but I'll need to check.  If I can output something from Premiere that Avid will take that's 4K, that would be perfect.
    Again, thanks for everyone's help.
    Media Composer 8.X (usually newest release), Avid matrix-recommended versions of both Nvidia driver and Quicktime, Matrox Mini MX02, Self-built machine... [view my complete system specs]
    I spend most of my time between New York and Los Angeles.  In Nebraska.
  • Tue, Sep 5 2017 8:28 PM In reply to
    4:2:2 works excellent at my system by linking playing back and transcoding.
    It might be the duration as well of a file but I am not sure about that either.
    Desktop
    Corsair RM750X/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.4/Corsair 32G DDR3/PNY Quadro P2000D(385.08)/Samsung 850 Pro SSD(OS) 256 GB/ 2x2TB WD RE4@RAID 0/LG BH16NS40/W10 Pro 64bit/Media Composer Software 8.9.3 with Symphony • PhraseFind • ScriptSync Option/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    3 Heads Digital MediaVienna Frames
  • Tue, Sep 5 2017 8:37 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,269
    • Points 42,290
    At this point, what we really need is someone with a GH5 do do a bunch of tests:
    In 8-bit (4:2:0)
    Link to short (5-minute or less) MP4 and QT files using Avid Generic and QT plug-ins.
    Transcode both using defaults.
    Transcode both using Set Framerate to Project.
    Link to long (20-minute or longer) MP4 and QT files using Avid Generic and QT plug-ins.
    In 10-bit (4:2:2)
    Repeat the same as for 8-bit
    The question is: What actually works (what links and plays back properly, and what transcodes properly)?
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC 8.7, MC 7.x [view my complete system specs]
    Dave S.
  • Tue, Sep 5 2017 8:47 PM In reply to
    • Vilem
    • Prague
    • Posts 1,395
    • Points 15,355
    Unfortunately, I have GH5 in service, so soon I can not do the necessary tests.
    The 4K 50p 8bit in "mov" works well with the QuickTime plug-in. But I'm working on the HD 50p project.
    Tomorrow I can try 50i or 25p.
    V.
  • Wed, Sep 6 2017 7:58 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 557
    • Points 6,285
    working on a short true 4k project here and everything is working fine.
    c4k_true 24p_4:2:2_10bit   all short clips linked with avid generic plugin
    they play flawlessly on my timeline (back and forth) linked to an ssd drive.
    now, just for testing purpose, i transcoded successfully a bunch of clips to dnxxhr hqx.
    i also recorded a test clip for 4:58.
    played fine on timeline but would not complete a transcode.
    i tried several mixdown and here's the results:
    dnxhr hqx      stopped at 2:56:14 (15.3GB file)
    dnxhr sq        stopped at 4:16:00 (14.6 GB file)
    dnxhr lb        stopped at 3:45:01 (4.01GB file)
    not  gonna jump to any conclusion now... :-)
    mc 2018.1 with symphony - QT essential 7.7.9 - win 10 pro64 creators - nVidia gtx1080 OC (388.31) - intel i7 6800k@4.1ghz water cooled by corsair H100i... [view my complete system specs]
  • Mon, Sep 11 2017 11:48 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 878
    • Points 11,295
    I made some tests with different methods of transcoding UHD/50p H.264 video created by Panasonic AG-DVX200, which records probably in the same format as GH5. The camcorder was set to UHD/50p, 150Mbit/s with QuickTime files, i.e., th H.264 video is wrapped with QuickTime to .MOV files. In total I used 23 consecutive clips with a total length of 3:43:10.
    The following tests were made:
    1a. Linking with Avid MC 8.9.1 with QuickTime Plug-In selected.
    Linking runs fast, timecode is correct, however many clips show only green frames. Even re-linking with Source Browser did not help in all cases. I checked all clips in Source Monitor and dropped them to  sequence, which crashed MC because again some clips show green frames when placed in the sequence.
    Transcoding the files to DNxHR SQ produced correct clips. Transcodeing is relatively slow. When running in Back Ground, Transcoding needed 13:25 minutes. When transcoding runs in direct mode, it needed 11:30 minutes.
    1b. Linking with Avid MC 8.9.1 with Avid Generic Plug-In selected.
    Linking runs fast, all linked clips play fine. However, all timecodes are wrong. Start timecode is one frame earlier, last frame of the clip is dropped. A consecutive sequence of clips result in one clip missing at any new clip on the sequence.
    Transcodeing in Back Ground is quicker than with QuickTime Plug-in. All 23 clips neded 9 mintes for transcoding.
    2. Transcoding source clips with TMPGEnc. Video Mastering Works 6 into DNxHR SQ
    It runs well, however extremely slow. The first clip with a length of 22:28 seconds needed more than 5 minutes.
    Linking the transcoded clips withSource Browser (QuickTime Plug-In) runs well. They do not show the problem of all green frames.
    The disadvantage is, that TMPGEnc. does not consider the timecode of the source clips. All clips start with timecode 00:00:00.
    3. Transcoding source clips with TMPGEnc. Video Mastering Works 6 into Sony XAVC S
    It runs well and is faster than in test 2.
    The clips were linked with the new nablet XAVC S-Plug-In. All clips are fine with no clip showing the all green frames error. Transcoding clips in Background is slow. It took 2:59 minutes to transcode three clips with a total length of 1:06:12 minutes.
    Again, the disadvantage is, that TMPGEnc. does not consider the timecode of the source clips. All clips start with timecode 00:00:00.
    4. Transcoding source clips with ClipToolz (a freeware tool) into ProRes 4K 4:2:2 Std.
    It runs fine and needed 11:47 minutes for all 23 clips with a total length of 03:43:10. ClipToolz transcoder runs with 18 fps on my workstation.
    The clips were linked with Source Browser. They all play nice. No green screens.
    A severe problem, however, is, that ClipToolz does not handle timecode correctly when source material is in 50fps or 60fp. The framecount of the first frame should be multiplied by two (it is correct when running in 25fps or 30fps), which leads to overlapping timecodes of the resulting clips.
    5. Linking source clips with DaVinci Resolve, and creating a timeline with the linked clips within Resolve
    It runs quick and reliable. Timecode is handled correctly.
    Output the sequence (timeline in Resolve) with the prdefined setting "Avid AAF" produces Avid compatible .MXF-files which can be directly imported into Avid Media data base (copy files into Avid MediaFiles\MXF\<decimal number>). Avid recognizes the new files. The associated AAF-file can be imported and gives exactly the timeline from Resolve with all master clips present in the bin.
    The file export (including transcoding from H.264 into DNxHR SQ) runs extremely fast. It needed 3:37 minutes for all 23 clips of total length 03:43:10 minutes. Resolve runs with 56 fps when transcoding/exporting on my workstation, i.e., it runs slightly faster than clips play in real time.
    All timecode information is correct.
    Summary:
    Currently the best mehod to get H.264 media into Avid MC is the way via Resolve. It is reliable quick and without any error. In addition one can make initial color corrections already before sending the clips to MC.
    Joachim
    Joachim Claus
  • Mon, Sep 11 2017 1:18 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,269
    • Points 42,290
    Nice test. The only issue I have with Resolve is that performance is largely based on the graphics card(s). If you were running something like a GeForce GTX 760 the performance would be notably worse. Of course, if you had a couple of GTX 1080's, the performance would be notably better.
    It's really amazing though; all of these products that deal with video, and many of them don't work fully in all cases.
    Dave S.
  • Mon, Sep 11 2017 3:36 PM In reply to
    • Joachim Claus
    • Posts 878
    • Points 11,295
    DStone:
    In my current workstation (the one I made the test with) I have a Quadro M4000. In my second (older) workstation I have a Quadro K2000D. I will do the same test there with the same Resolve version and will report the result
    Joachim
    Joachim Claus
  • Mon, Sep 11 2017 3:59 PM In reply to
    • Joachim Claus
    • Posts 878
    • Points 11,295
    I tested the transcode/Export of same set of clips with Resolve 14 on my older workstation (Quadro K2000D, dual Hex-core CPUs 3.4 GHz) and it took 6:32 minutes. The transcode/export process was running in Resolve with 32 fps.
    So, infact, the performance is not as high as with my newer workstation, however it is still better then transcoding inside MC 8.9.1.
    Joachim
    Joachim Claus
  • Tue, Sep 26 2017 5:00 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,269
    • Points 42,290
    MC 8.9.2 is now released. It fixed the transcoding issues for XAVC-S, which is also MPEG-4 based. See if that fixes the GH5 issue as well.
    Dave S.
  • Tue, Sep 26 2017 7:46 PM In reply to
    • touviere7
    • los angeles
    • Posts 557
    • Points 6,285
    indeed,
    i just tested with a 4k clip, 26 min. long, and i was able to complete a mixdown.
    YesBig SmileYes
    p.s.  gh5
           also linking with avid generic and transcoding a 23 min.  4k 4:2:2_10bit clip without problem (.mov).
  • Wed, Sep 27 2017 12:26 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,507
    • Points 58,920
    Good news! Let's hope Avid posts the announcement on this forum shortly...
    Cheers
    Camera(s) PXW-X70, HDR-FX1, Hero 3+ | MC 8.10 | QT 7.7.9 | BCC 11 | Sapphire 11 | Mocha Pro 5.5.2 | Titler Pro 6 | Windows 10 Pro x64 | System: P6X58D... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Sep 28 2017 11:31 AM In reply to
    • Joachim Claus
    • Posts 878
    • Points 11,295
    Currently, the best way to go, is using Black Magic Resolve 14 (free). Lload your GH5-files, place them on a timeline and then "Deliver" this timeline with "Avid AAF" setting. Select your desired codec from the DNxHR family, add this file to render, and then start the render process. You will get MXF-files, which can directly be placed in "Avid MediaFiles" folder. I recommend to cretae a separate "number"-folder under MXF, e.g., MXF\20. Then shift all the exported files from Resolve into this new folder. Open MC and import the .aaf file and you will have the sequence created in Resolve in MC with all media being present in the bin.
    Joachim
    Joachim Claus
  • Thu, Sep 28 2017 6:04 PM In reply to
    Joachim,
    if this is fixed why you propose a new solution.
    I am just missing something I am sure.
    Desktop
